Knock Sensor - Wiggles
Old Jul 19, 2006 | 06:07 PM
TobyZ28's Avatar
While doing the header install over the weekend I was able to get up close to the knock sensor on the block. Is it normal that it can wiggle a bit? The threaded part doesnt wiggle, just the connector going into the center of it.
Old Jul 19, 2006 | 06:57 PM
Re: Knock Sensor - Wiggles
The connector can spin around on the top of it. That does not mean it'ts not connected.
Old Jul 20, 2006 | 12:49 PM
Sweetred95ta's Avatar
What if it does more than spin? Like move up and down and side to side. Kind of reminds me of crinkly straw.
Old Jul 20, 2006 | 12:50 PM
TobyZ28's Avatar
Mine does more than spin as well.. it actually moves around (side to side, up and down, spins too) a good bit in there pretty easily
Old Jul 20, 2006 | 01:19 PM
Have you tested the resistance? I tried once but I couldn't get it to register anything. I tried grounding it on the block and the outside of the sensor. I'm just wandering if something has broken with all of that movement.
Old Jul 20, 2006 | 02:05 PM
As long as the metal contact on the connector remains in good contact with the terminal on the sensor, you're good.
KYWes
Jun 14, 2022 06:52 AM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
SergheiS
Jul 5, 2015 03:27 AM
4586
Mar 18, 2015 06:31 PM
