Knock sensor issues...
Old Sep 24, 2003 | 09:59 PM
HM Murdock's Avatar
The one in the block, not the PCM...
If the sensor was bad or somehow cut off from the PCM, say by the wire hitting the header, would the car run like crap? I am getting code 43, which means knock sensor or module fault, or ICM fault...I replaced the modules, bu noticed he KS wiring is VERY close to the header tube...Is this a possibility?
LT4 CC306w/1.6's and hooker LT's
Old Sep 24, 2003 | 11:23 PM
It has been suggested that a certain amount of timing retard is done by the pcm when that code is present (probably to protect the engine). That could be why you feel a drop in performance.
Old Sep 24, 2003 | 11:25 PM
RamAir95TA's Avatar
Damn...beat me to it.
I was going to say what shoebox said. When the knock sensor is seen by the PCM as not properly functioning, the PCM has no idea if any accurate knock is present, and retards the timing as a safeguard.
Old Sep 25, 2003 | 11:57 AM
HM Murdock's Avatar
OK, that makes sense, I'll tace the wiring and replace the sensor today.
Old Sep 25, 2003 | 12:21 PM
madwolf's Avatar
Let me confirm once again the above said, and add that the PCM will retard timing to its maximum value possible (and this is according to RPM and load) when there's a KS malfunction. As a result, the car will run very crappy.
Also,
The part that's in the PCM is called a Knock Module.
Old Sep 25, 2003 | 12:30 PM
HM Murdock's Avatar
Yeah, I know abou the module...Just wanted to be clear...I have already replaced the KM...No luck...Would the PCM retard timing to the minimum proscrbed by the table in the PCM? Because according to Freescan, it sure as hell is.
Old Sep 25, 2003 | 12:33 PM
madwolf's Avatar
Not minimum, but maximum. Yes, it will retard according to its KR tables.
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
