knock sensor desesitizing circuit
Old Sep 25, 2004 | 08:32 PM
Deenasty's Avatar
Does anyone know how to do this, that could help me out? I used the "search" fuction, but could not find a detailed one. Thanks guys!
Old Sep 25, 2004 | 09:34 PM
Re: knock sensor desesitizing circuit
http://www.geocities.com/MotorCity/6647/ta93/knock.htm
Old Sep 26, 2004 | 12:40 AM
chrism400's Avatar
Shoebox,
How have you been a member since 1969? I thought Al Gore invented the internet in the late 80's.
Old Sep 26, 2004 | 05:33 PM
Deenasty's Avatar
I am not too electronically skilled, and I am confused at this step:
Measure the resistance between ground and the blue wire that goes down to the knock sensor. Enter the resistance (in ohms) below:
How do I measure the resistance between gound and the blue wire? There is only one wire on the knock sensor.. Do you mean with the ohm meter, ground one side, and test the blue wire with the other side of the ohm meter? Thanks!
Old Sep 26, 2004 | 06:33 PM
slopokrodrigez's Avatar
Yes
Old Sep 26, 2004 | 06:34 PM
Yes. Basically, you are measuring the resistance of the knock sensor (but with a small amount of the lead wire connected to it).
SergheiS
Jul 5, 2015 03:27 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Fusion93Z
Jul 29, 2002 06:13 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
