knock sensor delete
Old Apr 17, 2007 | 10:40 PM
  #16
97Formy's Avatar
Originally Posted by crazydavez28
well i bought the car with the tune it has now and it will knock like crazy when you demand torque in high gears. the mechanic said it was deleted in the tune cuz it read knock but did nothing about it. i have LT's and RR's so i know i'd get some false knock. when i finally get me a laptop i'm gonna try to start tuning it better. also, i'm not familiar with the lt4 KM what does it look like? who knows i might even have it idk.
it has been doing this sort of thing ever since i brought it home over a year ago.
if my JE's and H-beams were gonna die they would have already
What type of gas do you use? Reg, mid or premium?
Old Apr 17, 2007 | 10:53 PM
  #17
crazydavez28's Avatar
premium only i think where i'm at premium is 91. i put 104 in it once and it ran incredibly better no knock problems at all (but i like eating more than driving ).
Old Apr 17, 2007 | 11:26 PM
  #18
97Formy's Avatar
I was only asking, and yes eating is better than driving. However you are getting knock, so I think you have a real problem that needs to be addressed.
Old Apr 18, 2007 | 09:01 AM
  #19
Loadre's Avatar
You can wire a resistor inline then ground the end of the wire to the block. Been running mine that way for years. Sounds like you have bigger problems than that though.
Old Apr 18, 2007 | 09:16 AM
  #20
Gripenfelter's Avatar
I run 94 octane with the KS disabled because my oil pan touches my Power steering and my long tubes tap the aftermarket K-member at WOT.
Old Apr 18, 2007 | 09:43 AM
  #21
foggedz's Avatar
I disabled the Knock sensor in my tune 7+ years ago. Never had any problems. Just set all of the knock retard tables to 0.
Old Apr 18, 2007 | 12:37 PM
  #22
maybe my CR is too high. i have forged JE flat tops with the single valve reliefs in a 355. and i got my heads milled last summer with stock gasket thickness. i believe stock ported heads but not sure
HectorM52
Jul 30, 2017 11:46 AM
99z28 carguy
May 26, 2015 11:35 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
