Knock sensor delete?
Old May 17, 2005 | 05:13 PM
Myxtreme1's Avatar
Can the knock sensor be deleted if you have the LT4 knock module?
Old May 17, 2005 | 05:33 PM
Re: Knock sensor delete?
The knock module has no bearing on deletion.
Old May 17, 2005 | 05:55 PM
Myxtreme1's Avatar
Didn't think so, thanks. The reason for asking is that I just so happened to forget to install it and a plug made it's way in it's place. Any tricks to getting it in? Thanks again!
Old May 17, 2005 | 06:09 PM
OBE1 95Z28's Avatar
If you're quick, you can switch the plug with the knock module with minimal coolant loss; you'll still need to top off the coolant system and burp it. The module has a very low torque value (something like 15 ft-lbs) so don't over tighten it.
Old May 17, 2005 | 06:53 PM
Myxtreme1's Avatar
Well I'm lucky there, there is no coolant in the motor .
HectorM52
Jul 30, 2017 11:46 AM
99z28 carguy
May 26, 2015 11:35 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
