Knock sensor
Old May 19, 2008 | 03:51 PM
Shaun Quill's Avatar
Knock sensor
Does anybody have a part number for an lt-4 knock sensor? My chevrolet dealer said it list the same number for lt-1 and lt-4 and I don't want to get the wrong one.Thanks,Shaun.
Old May 19, 2008 | 04:17 PM
rcantrellz28's Avatar
GM# 16214681 ........... I beleive thats what you are looking for.
ShownomercyZ28's Avatar
The sensor or the module in the PCM?
Old May 19, 2008 | 04:18 PM
My above response is the part# the for the module , located in the pcm........by the way.
Old May 19, 2008 | 04:36 PM
Thats a good Question,I believe you have to replace the knock sensor down on the side of the block don't you? Since the LT-4 is less sensitive it pulls less timing out Right? That's what I'm trying to do.I appreciate the help,Thanks
I think the sensor on the block is the same on both the LT1/LT4, but the module is different.
Old May 19, 2008 | 04:39 PM
This is what I have been told as well.
Old May 19, 2008 | 04:42 PM
Just did a quick search and ran across this. This should help you....https://www.camaroz28.com/forums/sho...4+knock+module
Old May 19, 2008 | 05:21 PM
There is not a specific LT4 knock sensor.
Old May 19, 2008 | 05:22 PM
wrd1972's Avatar
What he said.
Old May 19, 2008 | 06:22 PM
That straightens me out. Thank you fellas very kindly,Shaun
Old May 19, 2008 | 06:45 PM
Stl94LT1's Avatar
Isn't there different OBDI and OBDII knock sensors?
Old May 19, 2008 | 09:12 PM
Yes, but that was not the question here.
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
