Knock sensor
Knock sensor
i got a code 43 for it
i bought a new one like in march
i got a code after i had my cutout open but i closed it up now
still get the code, and ran a scan tool and it showed no knock @ all to the sensor
how can i check if its getin enought voltage, etc
what else could be the issue here?
Pull the wire of the ks, connect your meter up to that, and then to a ground. It should read around 5V.
If thats good then test the resistance from the tip of the ks to a ground. Im not sure of the ratings but there are a million posts here that have it on there, either that or wait untill someone kindly posts it.
14
Aug 11, 2015 12:03 PM
Noct
Jul 14, 2015 01:18 AM
