knock retard help
Old Nov 4, 2003 | 07:39 PM
818camaro95's Avatar
knock retard help
I'm getting 4 to 10 degrees of knock retard on my Scanmster @ WOT after I seafoamed the engine. I have no clue what's causing it?
Old Nov 4, 2003 | 08:26 PM
Josh-'04 GTO's Avatar
Well, you didn't include a sig or any info whatsoever about your car. My crystal ball is foggy today, so some info about your ride/mods would be a good start.
Old Nov 4, 2003 | 08:33 PM
Flowmaster exhaust
Hooker longtubes no cats
A4
New OVC wires
New opti
New plugs
Nothing major Anything else
Old Nov 4, 2003 | 09:07 PM
speed_demon24's Avatar
Do you have an LT4 KM?
Old Nov 4, 2003 | 09:16 PM
Yes I have LT4 KM. Forgot to add that.
Old Nov 4, 2003 | 09:20 PM
OBE1 95Z28's Avatar
Run it with race gas to see if the knock goes away; if it doesn't then you've got false knock. Brett Fraker's website has a link to installing a knock desensitation circuit to help with false knock.
Old Nov 4, 2003 | 11:26 PM
What if it's real knock? What would be causing it?
Old Nov 5, 2003 | 07:09 PM
up
Old Nov 6, 2003 | 02:29 AM
HungryT/A's Avatar
If you are running the stock pcm tune, there's a minimal chance that you are facing a real knock issue.
Anyway, a knock will occour with a lean condition and/or excessive timing advance. Theoretically, if you have bad plugs/wires, or suffer from lean condition (fuel pump/filter/pressure regulator/injector failure) you could be detonating.
Good luck
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
