knock retard
Old Aug 21, 2012 | 05:02 AM
Camaro350z28's Avatar
knock retard
getting knock retard on WOT runs. What should i start looking at to see if its false or not? should i run a higher octane and see if the knock retard stays?
Old Aug 21, 2012 | 11:23 AM
97z28k&N's Avatar
what octane have you been running?
Posted from Camaroz28.com App for Android
Old Aug 21, 2012 | 04:37 PM
Re: knock retard
92. my sig didnt update. longtubes and cai are bolt ons. plus pcmforless mail order
Old Aug 21, 2012 | 08:26 PM
Kevin Blown 95 TA's Avatar
Re: knock retard
Could be real retard, and some race gas might help you troubleshoot that, or you might have false knock from your exhaust banging or worn out engine mounts or some other mechanical noise. Your knock sensor might be bad if it is original equipment - they don't last forever. You're probably going to get a little on WOT shifts anyway, but that's supposed to happen. You could desensitize it if you wanted to.
Old Aug 22, 2012 | 03:20 AM
Re: knock retard
it was a little in the tune but anymore and he said it just be removing it. but 2 people looked at my datalog and didnt think the retard was good being there. ill check into my exhaust for banging or motor mounts bad. maybe swap the knock sensor
Old Aug 26, 2012 | 09:24 AM
OneShoe50's Avatar
Re: knock retard
Are you using the LT4 knock module?
Old Aug 26, 2012 | 01:22 PM
Re: knock retard
no. it was desensitized as much as it could be without completely making it useless
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
