knock=ses light?
Old Mar 24, 2008 | 01:19 PM
maro z28's Avatar
knock=ses light?
If your knock sensor picks up knock, will it just retard timing or will the ses light also come on. Maybe I'm just trippin', but I think I might be knocking. No ses light, though.
Old Mar 24, 2008 | 02:22 PM
ss.slp.ls1's Avatar
I believe it will just retard your timing, you'll have to hook it up to a scanner to see the actual knock retard.
Old Mar 24, 2008 | 02:49 PM
No code/light for knock retard. Only code you will get for the knock sensor would be a failure of the sensor or the wire, or a bad ground on the sensor.
But if you can hear knocking (detonation), it would appear the knock retard system is either not working, or that the required knock retard exceeds the amount permitted by the programming (~15* stock).
Old Mar 24, 2008 | 03:00 PM
maro z28's Avatar
I'm probably just being paranoid, cause I just got the knock sensor and wiring replaced. Also, the mechanic didn't pick up any knock, but i can hear a faint ticking sometimes when I accelerate. Rather seldom, but I still hear it.
Old Mar 24, 2008 | 04:27 PM
ss.slp.ls1's Avatar
I would start checking for an exhaust leak. Then look to the rockers.
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
