is a kn oil filter worth it?
Old Jan 30, 2004 | 12:35 PM
Seal's Avatar
is it worth to pay that extra 7-8 bux to buy the kn oil filter?
Old Jan 30, 2004 | 12:47 PM
gb95zconv's Avatar
Re: is a kn oil filter worth it?
I would say so based on the flow numbers on it....I use the long version of it (3002).
Old Jan 30, 2004 | 01:15 PM
Patman's Avatar
I definitely think it's worth it, as it flows extremely well, which is more critical than trying to filter out the smallest particle, especially in an LT1 which can tolerate 15 micron particles fairly well (one of the reasons these engines last so long)
Here is a recent independant oil filter test which shows how well the K&N flows:
http://theoildrop.server101.com/cgi/...c;f=6;t=001279
I use the K&N HP3002 oil filter, along with the German 0w30 Castrol Syntec, and that combination has given me the lowest engine wear numbers I've ever seen for an LT1 engine. (through oil analysis)
Old Jan 30, 2004 | 01:20 PM
Red96Lt1's Avatar
I've got one, and it's constructed very well on the inside. BTW, never use a fram! Their crap. They use to be good, but now someone else makes them, and they have a cardboard end cap, which I just don't trust. If nothing else the K&N has the cool 1" socket adapter on the end of it!
Old Jan 30, 2004 | 01:41 PM
SSnakeEater's Avatar
also beware of the oil from the filter getting into your Mass Air. the oil can coat the sensors and cause a false reading
GREGG 97Z's Avatar
I'm using the HP 3002, and I'd pay an extra $5 just for the socket fitting on the bottom, it is sweet Seriously though, it is the nicest filter I've seen for the LT1 by far. Lately I only put about 4-5K miles on my car a year and when I do I'm usually driving it like I stole it. So paying $9 for the best filter out there that I only change once or twice a year at most isn't a big deal to me.
FYI, Pep Boys now has this filter on the shelf for $9.99 which is cool (at least the one here does) I used to have to order them from Summit or other places.
Old Jan 30, 2004 | 03:06 PM
chasmanz28's Avatar
i agree K&N all the way, and if your useing syn oil its even better like stated above changing it once at 5k to 6k miles you need a good filter
Old Jan 30, 2004 | 06:46 PM
Seal's Avatar
I use synthetic, and change my oil every 3K (god knows how many times the prev owner changed it)
is the 3002 too long? i wouldnt want it scraping the ground when i go over bumps and stuff (i'm not lowered)
Old Jan 30, 2004 | 07:11 PM
Patman's Avatar
You've still got tons of room when using the long filters. I think it only runs into a problem if you're running long tube headers (someone correct me if I'm wrong)
Old Jan 30, 2004 | 07:27 PM
Cmr0z28's Avatar
There's a mass airflow sensor in the oil pan?
Old Jan 30, 2004 | 07:53 PM
Kain's Avatar
I just got one because the Mobil 1 oil filters were all sold out at two AutoZones.
I've still got good oil pressure. I'd get one.
Old Jan 30, 2004 | 08:14 PM
I1O0O1I's Avatar
what the hell are you talking about
Old Jan 30, 2004 | 08:21 PM
StoneRhino's Avatar
I used a couple on my old 2.8 EFI camaro, and was pretty happy with it. The thing I noticed the most was that the oil seemed to be cleaner at oil changes. I haven't used one on my LT1 yet though.
Old Jan 30, 2004 | 08:24 PM
ledfootz28's Avatar
where can i get a k&n oil filter.i havent been to pep boys or autozone in a while do they have them?or do i have to order it
Old Jan 30, 2004 | 08:33 PM
Kryckter's Avatar
I recently went to a pennzoil representative meeting and learned alot about these filters. The reason these filters have such a high flow rate is because the percantage of what is filtered is low. Factory specs for filtering is around 70-90%. That is what the factory filters can filter out and are relatively good. These K&N filters and Mobil 1 filters filter only about 30%. The reason they flow so good is because it doesnt filter down to the smallest microns. It pretty much like taking a normail screen and running oil through it. Its just not getting the small particles and in turn you get the higher flow rate. The best filtering filters out there are normally AC Delco for our cars.
