kinda dissapointed
Old May 12, 2006 | 12:00 PM
gbu27's Avatar
kinda dissapointed
well i finally got my pacesetter LTs and gmmg chambered all hooked up, and i dont really feel any dif. actually feels kinda slower. THat cant be can it, i hope not went from a stock monifold and flowmaster to that. also feels like something is bumping or grinding sometimes, could it be the ORY pipe or the steering column? ANyways i hope its just me thinking crazy that its slower, if nothing else, it sounds mean as hell
Old May 12, 2006 | 12:08 PM
scrmnws6's Avatar
Re: kinda dissapointed
Its faster. Take it to the track, the only way to find out.
Old May 12, 2006 | 12:11 PM
rskrause's Avatar
Moderator
It may well be slower. Headers often activate the knock sensor ("false knock") and the PCM pulls timing.
Rich
Old May 12, 2006 | 12:14 PM
gbu27's Avatar
so i need to go pick up a lt4 knock module then?, also would i be able to pick one up at the local auto store?
Old May 12, 2006 | 02:11 PM
Honda Hunter's Avatar
Order one from Dal. I didnt notice anything with my LT4 KM. Hook up a scanner and see if youre getting knock first.
Old May 12, 2006 | 02:17 PM
WS Sick's Avatar
Yep look at what the PCM is seeing before you start buying stuff.
It could also be and exhaust leak fooling the O2s.
Old May 12, 2006 | 02:56 PM
wrd1972's Avatar
If everything is working corretly you should feel a huge seat of the pants improvement (AKA butt dyno) over what you had. I know I did and I dont even have Lt's.
It is possible that you might be getting som timing retard, just get the LT4 KM and rule that out first. Check your plug wires real good then take it to the dyno to see what is happening.
Old May 12, 2006 | 03:06 PM
BradcTA's Avatar
...and a tune.
Old May 12, 2006 | 03:07 PM
njenson's Avatar
Originally Posted by BradcTA
...and a tune.
Seconded
Old May 12, 2006 | 03:16 PM
jsetzer's Avatar
Get a tune.
Funny things happen when you start modding and you don't always feel the results. My little lt1 is barely making 15lb more tq than it was same time last year. But it makes 80 hp more.
Get a tune, then get to a dyno and the track.
PopoFormula
Oct 12, 2015 04:19 PM
Godamnilovemy79
Sep 3, 2015 03:40 PM
97SSdude
Aug 21, 2015 09:36 AM
dkred94z
Aug 20, 2015 03:09 PM
