Keyed crankshaft hub for '95 LT1
Old Sep 24, 2006 | 03:42 PM
Eric Bazan's Avatar
Other than the Thunder Racing piece (which is on backorder). Who else makes a Keyed crankshaft hub? Thanks, Eric
Old Sep 29, 2006 | 05:12 PM
SC/TA's Avatar
Re: Keyed crankshaft hub for '95 LT1
Did you find one? I am looking for one also.
Old Oct 1, 2006 | 11:48 PM
Eric Bazan's Avatar
I just ordered the hub from jegs. I'll let you know in a two days how it works out. Eric
Old Oct 1, 2006 | 11:54 PM
wulfen33's Avatar
MTI in houston used to sell one.
Old Oct 2, 2006 | 07:08 AM
ssean92's Avatar
u talking about the hub that goes on the carnk and that the balancer bolts to? if so i have on with the 1/2 moon piece that goes in the crank.
Old Oct 2, 2006 | 06:26 PM
sskilla9three's Avatar
i had mine keyed at a local machine shop...just call around and see if they will do it. just have to know the specs of the key
Old Oct 17, 2006 | 03:22 PM
drifter60060's Avatar
Just got mine from Thunder racing. Had it in stock for the 92-95 LT1. Try 'em again.
Old Oct 17, 2006 | 03:44 PM
snakeatinZ's Avatar
Is this where it has a small notch in it so it will only go on one way?
Steve
Old Aug 12, 2009 | 09:51 PM
HectorM52's Avatar
When they key the hub, do they machine some of the inside of the hub? Is it still a TIGHT fit or is it less?
Dead thread, awaken!
Old Aug 13, 2009 | 07:10 AM
DAVE00's Avatar
Just get the one from Jegs as that is where I got mine about a year ago. Same quality and exact piece as thunder racing.
Old Aug 13, 2009 | 07:28 AM
HectorM52's Avatar
Was it still a press-on fit or is it looser than the stocker?
I know it's not going to be "loose" but is it "less tight" than the stock hub? Just curious.
Old Aug 13, 2009 | 07:50 AM
DAVE00's Avatar
It's still pretty tight fit, but you have the notch now for the key as well. It's a circular design for the pully mount vs. the stocker 3 arm and the only thing I had to do was remove the locator dowl they put in the face of it to work with their pully. The stock pully/balancer works like a charm with it.
Old Aug 13, 2009 | 08:45 AM
HectorM52's Avatar
Thanks man - that's exactly what I was looking for.
Adam
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
