K&N FIPK VS K&N FIPK Generation II
Old Apr 7, 2003 | 11:29 PM
CamaroGuy22's Avatar
Question K&N FIPK VS K&N FIPK Generation II
Ok, what in the world is the difference between these two?
Old Apr 7, 2003 | 11:35 PM
xxsaint69x's Avatar
umm there is only one K&N FIPK for the LT1
Old Apr 7, 2003 | 11:37 PM
Ok, i have no idea but check this site out, or check out the K&N website...
http://www.accessconnect.com/knairinject.htm
That shows you can get a new generation 2, or the old generation 1, i dont know what the difference is at all though..from what horsepower gains etc..
Old Apr 7, 2003 | 11:58 PM
tbehling's Avatar
i dont know how much diffence there could possibly be, they probally both have the same filter, so i am guessing theres not much difference in the two
Old Apr 8, 2003 | 08:41 AM
Old Apr 8, 2003 | 08:51 AM
pu12en12g's Avatar
I believe the difference is with the heat shield on the GEN-II style..
Old Apr 8, 2003 | 09:21 AM
Blk94Z28LT1's Avatar
if you notice, they both carry the same part number for the LT1
Old Apr 8, 2003 | 09:38 AM
mehoffz24's Avatar
the difference with the two generations is: this may not comply with the LT1 but. the generation 1 is a bigger cone shaped filter that goes on the factory air duct. the generation 2 is the cold air kit that we are all fimilar with. NOW if you speak to K+N they will tell you that they are both technically cold air kits becasue the 1st gen has an open element, so does the 2nd gen but the 2nd goes down into the fender or where ever it may be depending on application. when you order one and you speak to a tech make sure that you specify which one you want.
Old Apr 8, 2003 | 09:47 AM
But on an LT-1 they are the same thing?
Old Apr 8, 2003 | 09:49 AM
mehoffz24's Avatar
sorry for not answering your original question, im not to sure about that because i never bought one for my car, couldnt use it with the blower setup.
Old Apr 8, 2003 | 10:24 AM
CODY BEHNKE's Avatar
The Generation 2 just has a heat sheild added, the other kit they sell that adds a open element is a Filter charger kit.
Old Apr 8, 2003 | 10:29 AM
Does the heat shield give you any added performance, if so how much?
Old Apr 8, 2003 | 10:56 AM
Ace_437's Avatar
I highly doubt you'll see any gain from just the addition of a heat shield. Unless of course, you have an exothermic nuclear reaction taking place under your hood, raising the temp in the engine bay.
Old Apr 8, 2003 | 03:35 PM
BigRich's Avatar
i wrapped my K&N FIPK in silver foil insulator sheeting that had adhesive on one side.
HibachiZ28
Nov 6, 2015 12:53 AM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
drt
Sep 27, 2015 04:39 PM
jasonduaine
Mar 7, 2015 09:44 AM
ChrisFrez
Jan 18, 2015 08:05 AM
