K&N CAI not sealing up with MAF
Old 03-31-2006, 03:20 PM
StephenDeli22's Avatar
I got this problem ever since I bought the car. The K&N CAI does not want to seem sealed up on the MAF Ends. It just doesnt want to go on. In the event that I can/do get it somewhat good, it moves back to this position.
Do I need another rubber adaptor for the CAI or should I just go to Home Depot and get a rubber hose? Anyone else having these problems?
StephenDeli22 is offline
Old 03-31-2006, 03:23 PM
Cmr0z28's Avatar
Re: K&N CAI not sealing up with MAF
I go through the same problems with my SLP CAI.
Cmr0z28 is offline
Old 03-31-2006, 03:28 PM
3gc
3gc's Avatar
My moroso kit's couplers work well. If the K&N kit is the same setup as the moroso then i'd suggest going to the local ricer shop and get a coupler the appropriate size. Shouldn't be more then $10 or so.
3gc is offline
Old 03-31-2006, 03:30 PM
BradcTA's Avatar
I had to take my MAF off completeley and tighten it down really tight to the FIPK then hook it up to the engine.
BradcTA is offline
Old 03-31-2006, 03:41 PM
cn97z28's Avatar
My SLP CAI fit on very well and easy..the PITA was getting under the car to install the 2 air filters..
cn97z28 is offline
Old 04-01-2006, 12:11 AM
Whenever I would do that, in like 10 minutes of driving it would go back like to picture.
Old 04-01-2006, 12:28 AM
RedZ28Beauty's Avatar
Just sand off the edges a little bit so it will be straight and it will work just fine.
RedZ28Beauty is offline
Old 04-04-2006, 10:18 AM
94_6speedZ's Avatar
I also had the same problem with my K&N FIPK. I ended up using two clamps on the rubber coupler. I put them together outside of the engine bay. You can see the two clamps in the picture below. I've had it this way since June and it worked until i parked it for the winter in November. (Haven't gotten the car out yet this year)
-Greg
94_6speedZ is offline
Old 04-04-2006, 10:22 AM
jkucz31's Avatar
Same With Mine Only Not As Bad. Just Work With It A Little Bit Should Work Out Fine
jkucz31 is offline
Old 04-04-2006, 10:35 AM
z95lt1's Avatar
i have the same problem with my k&n cai but i dont think it is linking air in to the maf.
z95lt1 is offline
Old 04-04-2006, 10:45 AM
jkucz31's Avatar
oh wait look at your clamp it looks wayyyyy too tight anyhow try not to tighten it too much its just squeezing the maf right out
jkucz31 is offline
Old 04-04-2006, 02:54 PM
BradcTA's Avatar
Put the clamp as close to the MAf as possible. You may have to cut the "rib" off the radiator as per the K&N instructions.
BradcTA is offline
Old 04-04-2006, 03:27 PM
Do you think I can leave the FIPK in the car (airfilter is a PITA to get on and off) and just take off the intake elbow and try it that way?
Old 04-04-2006, 05:03 PM
BradcTA's Avatar
Yes. Just disconnect the intake elbow from the throttle body
BradcTA is offline
Old 04-04-2006, 05:30 PM
BlackScreaminMachine's Avatar
What I did was cut a hold in the part where the filter goes down into the well. So That I can put on or take off my entire intake setup from elbow to filter on and off.
Its a very common issue with the intake elbow, what we did as take me and my friend and we forced into place, it fits perfect. I also throught about hogging out that rib from the MAF to the CAI.
BlackScreaminMachine is offline
Kinglouui
05-26-2016 11:05 AM
Double aught
10-02-2015 11:29 PM
colts0455
09-27-2015 01:07 PM
SEOJustin
09-24-2015 04:39 PM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: K&N CAI not sealing up with MAF
