K&N CAI not sealing up with MAF
I got this problem ever since I bought the car. The K&N CAI does not want to seem sealed up on the MAF Ends. It just doesnt want to go on. In the event that I can/do get it somewhat good, it moves back to this position.
Do I need another rubber adaptor for the CAI or should I just go to Home Depot and get a rubber hose? Anyone else having these problems?
Re: K&N CAI not sealing up with MAF
My moroso kit's couplers work well. If the K&N kit is the same setup as the moroso then i'd suggest going to the local ricer shop and get a coupler the appropriate size. Shouldn't be more then $10 or so.
Originally Posted by Cmr0z28
I go through the same problems with my SLP CAI.
My SLP CAI fit on very well and easy..the PITA was getting under the car to install the 2 air filters..
Originally Posted by BradcTA
I had to take my MAF off completeley and tighten it down really tight to the FIPK then hook it up to the engine.
I also had the same problem with my K&N FIPK. I ended up using two clamps on the rubber coupler. I put them together outside of the engine bay. You can see the two clamps in the picture below. I've had it this way since June and it worked until i parked it for the winter in November. (Haven't gotten the car out yet this year)
-Greg
-Greg
What I did was cut a hold in the part where the filter goes down into the well. So That I can put on or take off my entire intake setup from elbow to filter on and off.
Its a very common issue with the intake elbow, what we did as take me and my friend and we forced into place, it fits perfect. I also throught about hogging out that rib from the MAF to the CAI.
