k member install?
Old Jun 21, 2011 | 09:13 PM
twistedbowtie's Avatar
Question k member install?
ive got my motor/ tranny bolted on the k member. i started lowering the body down and the struts are pulling in. im looking advise from some of you guys that do this regularly. is there any tricks to geting the studs through the firewall?
Old Jun 21, 2011 | 09:16 PM
RamAir95TA's Avatar
Re: k member install?
I'm going to assume you're talking about the studs on the shock towers? To keep them from flopping out I bungee'd them to the k-member temporarily.
Just go slow, lowering the body 1/16" of an inch at a time. Eventually you can pop them in so all four are in, then continue slowly lowering the body.
Ideally though it helps to have another set of hands, but it's not impossible with one person.
Old Jun 21, 2011 | 09:18 PM
thanks man are you saying bungee the shock tower from falling in towards motor ?
thanks alott
Old Jun 21, 2011 | 09:33 PM
You just have to baby it and go slow, lining them up as you go. Some wood blocks between the shock assy and the exhaust manifold can help keep them temporarily in place.
Old Jun 21, 2011 | 09:38 PM
RamAir95TA's Avatar
Yep - Rob's right. Just go nice and slow. A combination of wood blocks or bungees will work to keep the shock towers in place if you're flying solo.
Old Jun 22, 2011 | 10:15 AM
alright thanks guy. ima give it a try later tonight
LeftoverChinese
Jan 14, 2024 03:03 PM
4586
Nov 18, 2023 07:21 PM
cheapchevy
Apr 8, 2015 08:48 PM
Rde Bandit
Mar 21, 2015 10:17 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
