Just took apart optispark after misfire problems... (pics!)
Old Aug 29, 2004 | 11:32 AM
Eck's Avatar
Eck
Pics of my optispark
After having engine misfire problems for about a month and spending over $1,000 on new plugs, wires, installation, diagnostics, etc., and finally a new optispark... I think I've found the problem. Check out these pics of my old optispark.
Pic 1
Pic 2
That has got to be the problem. It burned a hole through the plastic and was arcing against the metal plate behind it... I'm so freaking glad to finally get this fixed! Just thought I'd share my joy.
Old Aug 29, 2004 | 02:08 PM
donot_4get's Avatar
Re: Just took apart optispark after misfire problems... (pics!)
how could you spend $1,000???
The only way I can see someone spending that much if the intallation was done by a dealer but still!
leo
Old Aug 29, 2004 | 02:14 PM
wicked_95z's Avatar
That's the funny thing about electricity. If your plugs or wires aren't providing sufficient ground. Electricity will find one for you
Hope the new opti fixes your problem
Old Aug 29, 2004 | 04:29 PM
Eck's Avatar
Eck
leo
Total it's actually $1,100, here's the list:
New factory plugs - $130 (I think?)
New factory plug wires - $140
Installation of new plugs, ignition coil, ignition module, injector cleaning, and misc. stuff - $350
Installation of passenger side plug wires - $120
New water pump (old one was starting to leak) - $110
New optispark - $180
Diagnosis @ GM - $75
So basically, after $1,100 my car is good for another 100k.
Old Aug 29, 2004 | 06:05 PM
transamdude95's Avatar
Haha, wouldn't that be nice?
Old Aug 29, 2004 | 06:44 PM
donot_4get's Avatar
Well, the good thing is that you got your car running good again
Next time, if you're going to replace them.. look up for aftermarket parts too, they might be cgeaper and perform better. the
MSD 8.5mm Spark Plug Wires, are much better than the stock ones and are $79.99 in thunder racing.... I think an electric water pump will cost you as much as you pay for your stocker too
Also try finding a friend that can help you intall all this stuff if not "offer beer or money" at the "lounge" and I'm sure someone will show up to help you out!
leo
edit-> NGK TR5 Spark Plugs, Stock heat range, gapped at .035 $2.25 (per plug at Thunder Racing)
Old Aug 29, 2004 | 07:01 PM
Z-RATED94's Avatar
Eck,
Thanks for sharing. You really do need to find a freind tho that will help you out when your having problems. This message board is great for help in that department, and all the trouble shooting guides that guys have put together to help people like you and me.
RUENUF
May 25, 2016 08:10 PM
Klypto
Mar 23, 2016 09:05 AM
RUENUF
Mar 13, 2016 03:39 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
