Just received Vortech elbow, thoughts...
I just got this piece and it is very pretty. The problem is the divider that runs the full length of the elbow on the inside. My n2o nozzle will not work with it becouse it will mainly run into the one side. Has anyone used this with n20 and isnt the divider just eating up air space? I guess Ill have to send it back and get the Trick Flow. Does anyone have any good installed pics of it? Can the satin be polished out to shine? Thanks
Re: Just received Vortech elbow, thoughts...
You should of post this in the N20 section might get more replys. As for that elbow some people cut the divider back, which takes some work. Or some run dual nozzles. I would go with the trick flow which I use and like it alot.
RUENUF
Mar 13, 2016 03:37 PM
CARiD
Sep 7, 2015 08:21 AM
