Just purchased my Data cable for my 95!!
Old Nov 13, 2011 | 10:56 PM
formula90's Avatar
I am excited. I have a OBDII connector and have a OBDI pcm behind it.
I have finally broke down and purchased my cable..
Does anyone here have any tips or tricks, software that they like to use to get a beginner off the ground?
Of course I just want to start by leanring how to check for codes, and also do some real time logging...
pretty neat..
It is the molded type that plugs right in to the ALDL port, with USB..
I purchased via aldlcable.com
Old Nov 13, 2011 | 11:00 PM
jit11375's Avatar
Re: Just purchased my Data cable for my 95!!
i'd check the computer diagnostics and tuning first. best of luck!
Old Nov 14, 2011 | 01:33 AM
MTL_Z28's Avatar
Here you go:
http://www.ttspowersystems.com/DataM...ownloads2.html
scroll down and download the 94-95 F-body complete install
This will give you 20 free trial runs.... Plenty for you to do what you want to do.
And here is a good link to help you interpret the new information:
http://www.injuneer.com/ScanMast.html
Good luck
Old Nov 15, 2011 | 11:43 AM
mguidry629's Avatar
^^^What he said.
I like tunercats to tune and datamaster for logging. Datamaster is free for the 1st 20 logs, then $100 to purchase (unless it changed recently). You can pause the log as many times as you want, or just turn the engine off and it will pause itself.
Old Nov 15, 2011 | 02:40 PM
JGuy07's Avatar
The software that is completely free is FREESCAN and it works pretty well I have had no problems with it. I use FreeScan for looking at data and codes myself. If I want to send a data file to someone for help then I have DataMaster since most people tend to use it more. DM gives you 20 free logs but after that you must purchase.
I also have injuneer's link above bookmarked and it helps you break down what everything means and how they may relate to each other, very helpful. I also went a step further and downloaded TunerCat and WinFlash for tuning purposes. It helped me to be able to look at tuning files and pull my own pcm tune out to see what I have or what problems may be there. I haven't tried any actual tuning yet, other then reflashing a stock tune on my pcm. Lots of things to learn and it will take a good while before you may be comfortable enough to do some things.
Old Nov 15, 2011 | 02:44 PM
formula90's Avatar
Thanks everyone.. I have my eyes on the mail for tomorrow or the next... should be here for the weekend!!
Old Nov 16, 2011 | 03:08 PM
JackBlack95's Avatar
Ordered mine yesterday. Ready to get this party started. Let me know how it goes.
Old Nov 16, 2011 | 03:11 PM
formula90's Avatar
Will do!
Old Nov 25, 2011 | 06:30 PM
formula90's Avatar
Ok, Installed Datamaster, and the drivers for Win7 x64 for the cable.
I recorded a bit, because I am chasing some anomoles...
https://www.camaroz28.com/forums/sho...96#post6830096
The above link is in the correct forum.
Thanks for the help!!
Old Nov 25, 2011 | 11:44 PM
See response to that thread.
jimmybandana
May 11, 2015 11:41 AM
95z_28_camaro_4_Ivan
May 10, 2015 09:28 AM
Jlo
Feb 23, 2015 12:20 PM
Jlo
Jan 21, 2015 10:11 PM
tbyrne
Jul 2, 2002 05:37 PM
