Just had an engine rebuilt, seems like there's problems
Old Jun 16, 2003 | 09:15 AM
thefox1's Avatar
Just got an engine rebuilt and there's already stuff going wrong!!
The first little thing I noticed is that it's ideling rough, and for the worst part, after 2 days I can hear knocking! It sounds like and old truck engine worn out! Any clues on what this could be? I'm bringing it bck in next saturday to have them look at it.
Another little thing I can't figure out where it goes is a little plug with an orange end. The wire comes from the bck of the brake master cylinder and I can't seem to find where it goes.
Old Jun 16, 2003 | 10:16 AM
rage366's Avatar
Re: Just had an engine rebuilt, seems like there's problems
ideling rough? did you get a camp swap? after it's rebuilt, it's best to reprogram the computer...
rebuilt to stock specs?
did your opti get changed?
were new plugs put in? new wires? were they in all the way?
knock sensor?
give more detail regarding the rebuild.
Old Jun 16, 2003 | 10:21 AM
thefox1's Avatar
Re: Re: Just had an engine rebuilt, seems like there's problems
knock sensor?
Rebuilt was done stock, opti+wires+plugs+ICM+ignition coil where changed at gm dealer in Febuary
Old Jun 16, 2003 | 10:43 AM
EvilRed93Z's Avatar
Is your oil pressure ok? Have you romped on it? Is it a knock or a clacking? Could it be your valve adjustments are a bit off?
Old Jun 16, 2003 | 10:53 AM
thefox1's Avatar
oil pressure is fine. Nop haven't hit her hard Would'nt be able to say about the valve ajustments, the garage will have to check that. It's definetly a knocking, sort of like if you put bad regular in instead of premium (knocks when it forces).
Old Jun 16, 2003 | 12:11 PM
pu12en12g's Avatar
Did you HAVE it rebuilt.. or did YOU rebuild it ?
Just curious...
Old Jun 16, 2003 | 01:38 PM
thefox1's Avatar
I had it rebuilt. Not enough time nor knowledge on my part to do it myself
Old Jun 17, 2003 | 07:54 AM
thefox1's Avatar
I noticed last night that the car was knocking under load, almost like the timing is off, is that possible?
Oncomingstorm22
Jan 22, 2015 07:15 PM
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
