just got a Z28
Old Nov 12, 2007 | 03:21 PM
Z28fan92's Avatar
Question just got a Z28
i bought a '96 Z28 like a wk ago. the guy told me it had a 350 LT1 Tune port in it, did not say if it was aftermacket or what. he told me it is a rareity b/c most '96's started using the vortec's. he said i had a corvette engine in mine. is this true? thanks
Old Nov 12, 2007 | 03:31 PM
Somebody is yanking your crank. All 93-97 LT1 F-Bodys are 350ci, with specific LT1 aluminum heads. The Vortec is a cast iron truck head, and was never used on the LT1. Because the LT1 has "reverse flow" cooling, and unique water passages between the block and heads, and a dry manifold, the Gen 1 SBC parts and the LT1 heads and intake (Gen 2) are not interchangeable.
Tuned port "TPI" was used to describe the L98 engine used in the 3rd Gen F-Bodys. The LT1 uses a plenum manifold, very short runners, and a full sequential fuel injection setup (94-97 only, 93 is batch fire).
There is virtually no difference between a Corvette LT1 and an F-Body LT1, except the Corvettes got a 4-bolt main block and the F-Bodys got 2-bolt mains. Identical blocks other than the mains.
Old Nov 12, 2007 | 03:56 PM
Z28fan92's Avatar
ah now i get it cool thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
