Just for fun, 10sec with 383
Old Nov 19, 2003 | 11:09 PM
Schurters LT1's Avatar
Talking Just for fun, 10sec with 383
Just thinking here can you go 10sec with a 383 full weight daily driven AND N/A what would the set up i need IE :
head
cam
so on
just for fun
Old Nov 19, 2003 | 11:20 PM
got_hp?'s Avatar
fully ported afr lt4's with ported lt4 intake
custom matched cam
wicked suspension setup + 12 bolt
drags
proper tuning!
Old Nov 19, 2003 | 11:25 PM
neil350's Avatar
Yea, I cant see why it couldnt be done. Esp if you could get that car to sixty on tires.
Old Nov 19, 2003 | 11:33 PM
kmook's Avatar
Advanced Tech Moderator
lol you should have specified staying at 23* heads.
But since you didnt i'll say sb2.2 or brodix canted heads on a 383 and go 9s.
Old Nov 19, 2003 | 11:38 PM
96speed's Avatar
Wink
Since 99% of us haven't done it, I'd say we don't know what it would take. Talk to Steve Quinn if you can - He knows what's going on.
Ryan
Old Nov 19, 2003 | 11:45 PM
neil350's Avatar
Ryan
Yea, theres a lot of factors to it. Jordan did it with a 396. making the power isnt the problem, just getting to hook and go down the track. That and what ever the deffintion of full weight it is.
Old Nov 20, 2003 | 06:20 AM
Fastbird93's Avatar
I thought Jordon did it with a 401??
Old Nov 20, 2003 | 09:10 AM
Grease's Avatar
Since this is just for fun
Donovan aluminum block
Callies magnum X-S 4340 crankshaft
Carillo billet rods
JE pistons
Custom ported AFR 215 RR heads
Hogan sheet metal intake, AS&M Monoblade TB
Solid roller camshaft somewhere around 24x/25x (daily driver cam)
Jesel shaft mount rockers
Crane Endure-X lifters
FAST engine management
Canton oil pan
Hooker LTs and Mufflex 4" catback
Huge fuel system and injectors
BMR upper and lower control arms, k-member, LCAs, panhard bar and STB
Madman torque arm
HAL 12-way shocks
Eiback drag launch springs
Brembo brakes
12-bolt with all the bells and whistles
Denny's "Nitrous Ready" driveshaft
TH400 with GV overdrive and 4000 stall converter
Or if you have an T-56, Mcleod Street twin (rebuilt of course with cryogenically treated internals, forged shift forks etc)
Plus a Pro 5.0 shifter
Lightweight cowl hood
Racing seats, 5-point harness and roll cage
Bogart 15x10 and 15x1.3 racing wheels
ET streets (for the street)
Did I miss anything?
Old Nov 20, 2003 | 09:56 AM
KCFormula's Avatar
Joe Overton went 9.7s with regular AFR 227s.
Grease, a Donovan block is not a LT1 block.
Old Nov 20, 2003 | 10:07 AM
Grease's Avatar
He didn't say anything about the block
Besides, if you paint it black, who will know
Old Nov 20, 2003 | 10:14 AM
Shon Herron's Avatar
I say it can be done with less cubes than 383. I honestly believe a 350/355 can do it and still be streetable....but the question is what do you consider streetable?
It will have to be lightweight, the right suspension set up, track prep to hold the fun, and the right H/C set up. Weight less than 3350 will be needed.
Local guy went 11.4s@119.5 with a miss at 6200/6300 with a 355 set up. Get that miss fixed and he is at 11.2s at least. Take out the rest of his interior and more cam and head and I believe he will be there....it might even take a solid roller set up but it can be done.
Old Nov 20, 2003 | 10:17 AM
KCFormula's Avatar
There is a guy on this board that goes 11.0s with a 355 and stock (ported) head castings. Oh yea, and its a 6spd car!
I want to build something similar, only use AFR 227s.
Old Nov 20, 2003 | 01:28 PM
kmook's Avatar
Originally posted by aggiez28
396...401 same thing basicly just different bore
I thought he had a 409.
Old Nov 20, 2003 | 01:41 PM
96z's Avatar
96z
I think most importantly is some good air and good track. Your not running anywhere near 10's with an NA 383 in Denver. A low raceweight is a must too and an A4 makes the job alot easier.
Old Nov 20, 2003 | 02:07 PM
funina91ss's Avatar
I went 11.11 with 447RWHP & 470RWTQ so a 383 should put that out. I did take the back seat out but other than that it is heavier than a stock f-body with the 6 point bar and sfc. and the 25lbs N20 bottle
