Just dyno'd the car with GTP's & Hot Cam
Well not very happy but it seems my Air Fuel needs some addressing. I will post a pic of the dyno sheet later. They could not get a torque reading for some reason.
They said they never seen that before. Anyway my max power was 345.3
Max A/F was a bit rich I believe. It ended at 12.2 but started at around 14 but droped straight down to the 12's.
My dyno before this with just the Hot Cam netted me 324.5 HP through cats. My A/F went from 14.5 to 13.5 on that one..
What do you think...
They said they never seen that before. Anyway my max power was 345.3Max A/F was a bit rich I believe. It ended at 12.2 but started at around 14 but droped straight down to the 12's.
Re: Just dyno'd the car with GTP's & Hot Cam
Your obviously dissapointed, hopefully you'll find some more power with better tuning. Good luck to you on that.
Re: Re: Just dyno'd the car with GTP's & Hot Cam
Originally posted by 94formulabz
Strange since HP is caculated from torque and RPM.
Actually the a/f ratio doesn't look that bad. I think it'd make a little more power if it were leaned out just a bit. The 360ish someone mentioned sounds reasonable.
Why didn't they log it vs rpm instead of mph?
I don't understand why someone would do that?
Also, you have a pm.
Re: Re: Re: Just dyno'd the car with GTP's & Hot Cam
Originally posted by TheHeadFL
It would seem that way wouldn't it? But this is not how a dyno measures your torque. All a dyno can measure is the RPM of the drum (and therefore accounting for gearing the engine) over time. Basically, using calculus, one can arrive at the actual horsepower and torque figures.
Hydraulic Brake/Waterbrake engine dynos like the ubiquitous Superflow 901 load the engine, measure tq, and calc hp. The inertia dynos like the standard issue dynojet 248c however, as someone else mentioned, measure power based on accelerating the known mass/m.o.i. & calcs tq from that.
As far as I know anyway
-Phil
-Phil
Originally posted by joeSS97
I bet with tuning you will hit 360 rwhp easily,probably higher.
Originally posted by Josh-'97 WS6
I don't think that is out of reach. The 12.2:1 at peak HP is nearly a full point off! Most NA engines prefer right around 13.1 at peak HP.
I hope your right. I will be completely satified with a 360 RWHP dyno pull through a large stall like I have. (3600) I guess it is how it performs at the track that only matters. It runs good so............. I Dunno...
Dyno's are a good starting point but it really matters at the track.
Congrat's on getting things back together again.
Don't sweat it, takes time to fine tune it.
