Just bought a camaro z28 roller with 4:10. Engine help!!
Old Feb 2, 2011 | 01:25 PM
CHAZ8677's Avatar
Just bought a camaro z28 roller with 4:10 GEARS. Engine help!!
I wanted to know if i should go with a carb ls1 or carb 6.0? Any suggestions!!! I BOUGHT A 400 TURBO TRANS FOR THE CAR ALREADY!
Old Feb 2, 2011 | 03:16 PM
red94chicken's Avatar
Re: Just bought a camaro z28 roller with 4:10. Engine help!!
Why the hell would you want to put a carb on anything? Second. Why not put the engine intended for the car. If its an ls1 car then put that in it. A 6.0 depending on what it came out of would be the deal breaker. Possibly some details about what year the car is.
Old Feb 2, 2011 | 03:48 PM
What are you using the car for - street or strip?
Old Feb 2, 2011 | 08:14 PM
CHAZ8677's Avatar
MOSTLY STRIP maybe ill drive it on the street sometimes..Im going with a 400 turbo tranny with a 3500 stall...(Injuneer) whats your best suggestion? Its a 97
Old Feb 2, 2011 | 08:23 PM
RamAir95TA's Avatar
IMO you need to do some serious searching to determine what is possible, and what you want out of the car. Establish some goals (HP/ET, etc.) and a long-term budget, then determine whether or not converting to an LS-based motor is worth it to you or not.
Old Feb 2, 2011 | 08:31 PM
CHAZ8677's Avatar
appreicate that RamAir. nice car! are you supercharged?
Old Feb 2, 2011 | 09:09 PM
RamAir95TA's Avatar
Thanks man.
No boost or nitrous, all motor. Nothing fancy.
fpete1992
Dec 11, 2014 03:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Bearmans
Dec 3, 2014 05:28 AM
siguy
Nov 27, 2014 10:07 AM
grendal
Apr 15, 2010 05:20 PM
