Just Bought Cam...and the questions begin
Old Oct 28, 2006 | 01:25 AM
johnny3986's Avatar
Question Just Bought Cam...and the questions begin
Well, I just bought the COMP CAMS LT1/LT4 XTREME ENERGY 276 CAMSHAFT #07-503-8 because I want to make some power, but not have to spin to high heaven to get it. Call it "383 Build Fear" if you will...
Specs are 224 int./230 exh with .510/.530 lift on a stock 1.5 ratio.
I am looking to see if 1.6rr are giong to benefit me more than 1.5rr. Another guy with this cam ran the 1.6's with no problems.
This a good idea? Lifters and pushrods are being replaced at the same time.
Also, Comp Cams recommends the 26918-16 springs, which are the beehive ones. I searched, and a couple people had problems with them breaking...
Any other springs I can run that won't require head modifications that might be better??
(I am under the impression through searching that the 918's do not require any mods to the heads.)
Old Oct 28, 2006 | 01:47 AM
MachinistOne's Avatar
I think some people don't know how to warm up their car before putting the hammer down. That is how 90% of the spring breakages that I see occur.
Yes - use 1.6 rockers...how many miles are on your motor? Stock motor? Heads?
Old Oct 28, 2006 | 01:52 AM
jay_lt4's Avatar
great cam, i have a 503 with 1.6 rollers and look what it runs and still gets 20mpg
Old Oct 28, 2006 | 02:06 AM
johnny3986's Avatar
75K miles, stock heads/internals.
Money set aside for rebuild, but between collge, full-time job, and firefighting...no time :-(
Those springs okay? Or you guys suggest something else not requiring head work??
Old Oct 28, 2006 | 02:52 PM
seawolf06's Avatar
I would use the 918's, and I am! Just go through several heat cycles and oil changes before getting on it too hard.
95chwagon
Feb 28, 2015 12:02 PM
rwferguson43026
Feb 6, 2015 10:06 AM
cmdeshon
Dec 27, 2014 10:06 AM
Dec 1, 2014 08:08 AM
