Just Bolt on's 1/4mile times 6spd Lt1's only
Old Nov 24, 2009 | 05:56 PM
joeytweaks's Avatar
I wana get some idea's of what it is that gets my 6spd into the 12's this year...tks Tax's on there way!!!
Old Nov 24, 2009 | 06:13 PM
hsyr's Avatar
Some LT headers, cutout or good catback exhaust. Roller rockers either 1.6, or 1.7s. A CAI kit, e-water pump, airfoil, underdrive pullies, 4:10 gears + drag radials. Probably will have to upgrade the clutch and maybe look into a tune. That should get you there, if not time to put a bigger cam in it.
Old Nov 24, 2009 | 06:24 PM
joeytweaks's Avatar
tks......keep it coming!!! ill have about 2500 to spend
Old Nov 24, 2009 | 08:34 PM
bw_hunter's Avatar
Make it breathe and get it to hook up..that's all you have to do...LOL. A CAI will help on the intake side, headers and a nice catback on the exhaust side. 1.6 ratio roller rockers and a tune. On the traction side, add better LCA's, LCA relocation brackets. Drag radials will help you hook up.
No disrespect intended for the previous poster but stay away from 1.7 roller rockers...too many geometry issues and don't bother with underdrive pulleys...since the waterpump is driven off the cam there isn't much to gain slowing down the alternator and power steering pump.
Old Nov 24, 2009 | 10:12 PM
Blkdragon's Avatar
CAI, longtube headers, catback or true duals, a tune, and some Mickey Thompson's should get you in the 12's or pretty damn close.
Old Nov 25, 2009 | 12:20 PM
JoeliusZ28's Avatar
I ran 13.56 at 105 with just intake/exhaust/clutch. Street tires & stock gears at a track with the WORST prep ever.
Old Nov 26, 2009 | 09:14 PM
Bowtie4life's Avatar
I bet the track I run at has worse prep, anyways, with mods in sig, car has a best of 13.5 @ 106.4 on a 2.21 60' and spinning a third of the way through 2nd, get to try out a friends drag radials tomorrow, hopefully.
Old Nov 27, 2009 | 08:04 AM
petie's Avatar
Lt Headers, a CAI, and 4.10's with some sort of sticky tire should do it.
Old Nov 27, 2009 | 10:46 AM
starbucks's Avatar
I went 12.78 at 108 with a cold air long tubes and a 9 inch with 3;89 gears
Old Nov 27, 2009 | 11:37 AM
6Speed's Avatar
instead of ud pulleys u can ditch your belt for a run too
Old Nov 27, 2009 | 11:48 AM
87Aerocoupe's Avatar
With that much to spend I would contact Lloyd Elliott or AI and get a head & cam package, new head gaskets, 1.6 rrs, LT headers and 4.10's and that should get you in the high 11s - low 12s.
Old Nov 27, 2009 | 02:49 PM
hsyr's Avatar
$2500 isn't going to get you ported heads, cam, supporting valvetrain, Lt headers and 410's Used parts maybe, and what about labor? Not trying to sound like a **** but it isn't doable with new parts.
Old Nov 28, 2009 | 12:22 AM
JoeliusZ28's Avatar
are there 'speed bumps' from cracks in the asphalt near the christmas tree?
Old Nov 29, 2009 | 12:08 AM
Wooshie's Avatar
Whats wrong with used parts? The only brand new parts on my car are the valve springs and opti. I have gears, LS1 ram air conversion, cam, rockers, fuel pump, air foil, ported stock tb,LT's, and tons of suspension parts that are all used. BTW I have less than a grand invested for all of that. I'm running mid 12's. Just something to think about.
Old Nov 29, 2009 | 11:00 AM
hsyr's Avatar
Nothing is wrong with used parts, just saying he will be hard pressed to do a H&C package + boltons for $2500.
