jump in compression worth it?
Old Feb 7, 2005 | 09:38 PM
unvc92camarors's Avatar
planning on doing headers soon enough and was wondering if it's worth it to go with a thinner head gasket to increase the compression
how much hp would it give?
i run on 93 so i'm not worried about increasing compression since the octane is enough already as is
Old Feb 7, 2005 | 10:04 PM
Larnach's Avatar
Re: jump in compression worth it?
Its not really worth it, I'd stick with the standard head gaskets. Stick with Fel-Pro's.
Just my 2 scents, I've done heads several times, stick with what works. Not saying it won't work, but I'd rather not deviate from the stock setup.
Old Feb 7, 2005 | 10:16 PM
blackztpi's Avatar
it's picky, but some argue better fuel burn and more effeciency with more compression. general rule of power is 10-15 hp per full point of compression raised. so by that, you're not gaining much, but for many its a state of mind.
Old Feb 7, 2005 | 10:18 PM
LameRandomName's Avatar
Well, assuming that you'll still have sufficient valve clearance with the gasket you have in mind I would tend to think that the main benefit would be a tighter quench which will increase your detonation resistance. I mean, you might get a small power boost, but enough to notice...? I honestly don't know.
Old Feb 7, 2005 | 10:25 PM
amean94ta's Avatar
shave your heads to 50cc's then use a thin gasket thats worth 25hp or so
Old Feb 7, 2005 | 11:17 PM
SStrokerAce's Avatar
In a LT1 block it's a good idea.....
The block has a higher deck height than a SBC and the stock gasket is very tall so going to a Impala gasket is really the way to go. It's still not even small enough to worry about
Bret
Old Feb 8, 2005 | 06:14 PM
96capricemgr's Avatar
It isn't worth the trouble unless pulling the heads though is it? He said he is doing headers so yes he will be partway there but still a lot more work to do the head gasket over just the headers.
Old Feb 8, 2005 | 06:17 PM
mourningyou's Avatar
what else do you have to modify tho? intake? rockers/etc ?
Old Feb 8, 2005 | 11:45 PM
Nothing really it's just a head gasket swap....
If I was in there, I would do it. If you are going as far as headers it's just some more things to take off anyways.
Bret
Old Feb 11, 2005 | 11:53 AM
amean94ta's Avatar
yeah just that nothing else needed
surreybrad
Sep 29, 2015 09:00 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
