Joe o Cam
Old May 24, 2006 | 04:10 PM
OrbitalChris's Avatar
Joe o Cam
hey guys, I just got my Joe O custom grind cam, and it came in a erson cams box, and stickers and stuff, does anyone know why this is...thought it was supposed to be a custom grind??
thanks for your help!
Chris
Old May 24, 2006 | 04:22 PM
MAJESTIC's Avatar
Re: Joe o Cam
Chris
I am sure it was just used for shipping
He's not gonna say he selling you a custom grind
and then send you a erson cam.
does it say erson on the end of the cam??
Old May 24, 2006 | 04:25 PM
Kevin Blown 95 TA's Avatar
Re: Joe o Cam
Relax, there are hundreds of lobe selections at the cam grinders and he can specify his own or put together a combo of lift & duration that he likes from a stock library and have someone else grind it on million dollar CNC equipment and get it dead nuts to his specs. In that sense, it's custom, but not like he did it in his machine shop on his own cam grinder which you might not want anyway. Erson makes damn good cams, so stick it in, degree it, and good luck!
Old May 24, 2006 | 04:28 PM
1SlowFormula's Avatar
Re: Joe o Cam
Don't worry, like most guys that do custom cams they mearly spec it out for you and give those custom spec's to a company that actually grinds the cam, yours was probably ground by erson cams, but is not an off the shelf cam and a custom spec'd one from Joe ground by them...
Old May 24, 2006 | 04:32 PM
Heatmaker's Avatar
Advanced Member
Re: Joe o Cam
Joe Overton doesn't make cams, he designs them. Erson, is the manufacturer that he choses to have make the cams for him. So that cam is your Joe Overton custom designed but manufactured by Erson.
Old May 24, 2006 | 04:34 PM
Re: Joe o Cam
ooo I thought it would be something like that, thanks alot for your help guys!! i dont want to post up the specs out of respect, but ill let you know what kindof power I put down, and put in a vid or something!! thanks again
Old May 24, 2006 | 05:50 PM
ABA383's Avatar
Re: Joe o Cam
You'll love Joe's cams...Mine, however, did not dyno very well and when I posted the numbers I was told that something must be wrong, my cam made blah blah blah, I must have a problem, etc....Then I went to the track and posted those numbers. Then it was a different story. The dyno is a great tuning tool and thats it. Mine is an Erson grind also and its small for a 383, but it works well and still gets 20 mpg on the highway. The times in my sig are with my old shorties and stock wp...We've changed a few things this year and are heading to the track Friday...You'll be happy. I've never seen a Joe O cammed car run slow...
--Alan
Old May 24, 2006 | 06:02 PM
96speed's Avatar
Re: Joe o Cam
Yup, most "cam guys" don't have the actual CNC/lathe machines. There are some smaller shops that actually grind cams (I've only used one personally, but I'm SURE there are plenty more) for different cam masters, but for the most part Comp, Crane, Isky, Crower, Erson, etc, are churning out the cams.
Ryan
Old May 24, 2006 | 06:22 PM
1racerdude's Avatar
Re: Joe o Cam
I don't have the money for the equipment nor the time to learn how to use it(at my age). Cam grinding with a lathe set up for cams is an art.
Most company's today do it with cad machines.
Old May 24, 2006 | 09:59 PM
LT4POWR's Avatar
Re: Joe o Cam
Chris
you actually thought he was grinding them himself
Old May 24, 2006 | 11:37 PM
T/A KID's Avatar
Re: Joe o Cam
ABA383 what heads do you have Ligenfelter, LE, AI,or Joes Porter
Old May 25, 2006 | 05:36 AM
Heatmaker's Avatar
Advanced Member
Re: Joe o Cam
I did too at first, then I was like... ohh what a minute...
Old May 25, 2006 | 06:51 AM
White H/C 94Z's Avatar
Re: Joe o Cam
I thought he didn't do cams anymore???
Old May 25, 2006 | 08:33 AM
bdc95ta's Avatar
Re: Joe o Cam
My Joe O cam also cam in an Erson box.
-b
Old May 25, 2006 | 11:07 AM
Z-RATED94's Avatar
Re: Joe o Cam
-b
Same here.
