Jet Hot vs. Hooker Headers
Old Dec 19, 2003 | 09:14 PM
95Bluestreak's Avatar
I saved up some money and christmas break I am going to buy some lt's. I would like hear your opinions about the two, the pros and cons. Iv'e heard about clearance issues with the jet hots, and the hookers have a higher price tag. The $ is not an issue I want the better quality of the two. Thanks, Jason
Old Dec 19, 2003 | 09:24 PM
PatriotTA's Avatar
I have been rolling the same question over in my mind. I've decided to go with the Hookers, even though they are more expensive. I have heard of clearance issues with the Jet Hots, too. Plus, Hooker has been around for years and years and Jet Hot LT1 headers have only been around for a year or so. I'd rather spend top dollar for a tried and true brand name, just for the peace of mind. I'm sure a lot of people are going to call me stupid since Jet Hots are based on Hookers and use thicker tubing that hookers and are less expensive, but oh well, that's my opinion.
Old Dec 19, 2003 | 09:35 PM
FacelessZ's Avatar
Jet Hot LT's are exact renditions of the Hooker LT's...just thicker gauged metal...
As far as a difference in quality there really isn't much of one and as far as fitment issues with the Jet Hot's most people don't have them...so I'd say save around $100 and go with the Jet Hot's...
Old Dec 19, 2003 | 09:42 PM
Antz97ZNJ's Avatar
dont think theres much of a differance at all...go w/the better price
Old Dec 19, 2003 | 09:44 PM
Camaro_Maniac63's Avatar
If money is not as issue, then go with the TPIS long-tubes...
Old Dec 19, 2003 | 09:56 PM
FacelessZ's Avatar
haha of course go TPiS or Finish Line Performance if 'money ain't a thang'
Old Dec 19, 2003 | 10:25 PM
revtime's Avatar
I have Hooker Jet Hot coated LTs, I like them alot and after seeing Jet Hots version I would not hesitate to get either one.
Old Feb 10, 2004 | 07:10 PM
95 Silver TA's Avatar
TTT...I am at the same cross roads now and want to know which of the 2 are the better ones.
Does either one have any slip fit primaries?
Does either one hit the steering knuckle or anything else?
Is plug access the same?
Thanks,
Claude
Old Feb 10, 2004 | 07:16 PM
Xride's Avatar
Thanks,
Claude
they are the same.
if you look on the jethot site they actually say hooker super comps, coated with emmisions and O2 bungs.
same thing, but hookers and then locally coated are way cheaper.
Old Feb 11, 2004 | 11:30 AM
FacelessZ's Avatar
Originally posted by Xride
they are the same.
Coated Jet-Hot's are cheaper than coated Hooker's...
Old Feb 11, 2004 | 11:44 AM
93redbird's Avatar
If you do a search on this, you will find that alot of people have issues where the collector is not paralell with the bottom of the car and actually bends up to the cross memeber. I had this issue on my 97 formula with jet hot longtubes. Also the Jet hot longtubes have a slip fit number 1 primar on the drivers side. The hookers do not.. This is a leak issue, but I dont know if it makes a difference. Also some people that have this problem with the collector going back up to the car blame it on the motor mounts.
Let me know if this helps. I had them installed and did it myself... let me know if you have any questions.
Tim
Old Feb 11, 2004 | 12:01 PM
fastcamz28's Avatar
Doesn't Jet Hot use a variety of manufacturers and simply apply their coating? In our case, their LT/shorties for LT1's /LS1's are Hooker w/ Jet Hot's coating, or so it appears from their website.
Old Feb 11, 2004 | 12:48 PM
93redbird's Avatar
Hookers dont have slipfit primaries... Jethot does... and the header tubes are tac welded to the flange and not welded around fully, which kinda looks shotty but there arent any leaks so I guess it doesn matter.
Tim
Old Feb 11, 2004 | 01:00 PM
anasazi's Avatar
the hooker longtubes laying in my garage say otherwise
Old Feb 11, 2004 | 01:10 PM
turbo_Z's Avatar
Yeah there seems to be 2 versions of the hooker LTs out there.. 1 have teh slip-fit #1 and the other does not.
IMO.. and keep in mind i dont have LTs... but from what ive heard on there the jethots have some issues. some people sya they go right in without trouble while other people have resorted to hammering them in place.
