Jet Hot V.S. Hooker PICS INSIDE !!
Old Aug 2, 2005 | 05:12 PM
  #16
CamaroSS30thAnn's Avatar
Re: Jet Hot V.S. Hooker PICS INSIDE !!
Originally Posted by Valkyn71
Mine are dam close to the floorboard, i replaced the motor mounts with ES Poly mounts, and it didnt move them any.
almost every mount on my car is poly , lol i dont think its my fault my jet hots dont fit
Old Aug 2, 2005 | 06:26 PM
  #17
Valkyn71's Avatar
I didnt say it was, i was just saying that its not always sagging motor mounts like the guy i quoted was suggesting.
Old Aug 2, 2005 | 11:47 PM
  #18
lt11997's Avatar
My Jet-Hots fit just fine and my engine has 106,000 miles on it with the original motor mounts.
Old Aug 2, 2005 | 11:50 PM
  #19
i know
that was just aggrivation speaking wondering y mine are gay lol
Old Aug 2, 2005 | 11:53 PM
  #20
revtime's Avatar
I bought Hookers and then sent them to Jet Hot to coat them. It did cost me more, but they still look decent after 26k and they fit perfectly......well I did have to grind some on the tranny crossmember but thats cause I run true duals with purple horny header muffs.
Ground clearance is not the best but I run an Eibach drag launch kit and it jacks the *** end up so it helps out as long as my exhaust mounts don,t break.
I ordered mine without O2 bungs and just welded O2 bungs into my hornies, I can turn em any which way I want and then tighten em up.
Old school has its advantages.
Old Aug 3, 2005 | 05:47 AM
  #21
PoorMan's Avatar
I never understood the round vs d-flange thing. I mean; you still got a d shape hole going into a round tube either way. Think about it....
JD
Old Aug 3, 2005 | 02:50 PM
  #22
Z97LT1's Avatar
Good post. Headers are one of the most important components of any buildup.
The quality of the Jet Hots definitely looks superior.
One concern, however. The front primary of the drivers side Jet Hot looks like it has an individual flange, as in not connected to the rest of them. I've had some unpleasant experiences with MAC shorties having individual flanges warping and leaking if they are removed and reinstalled more than once...
A flange connecting all of the primaries prevents that.
Old Aug 3, 2005 | 04:30 PM
  #23
^^Jethots are def superior in welds and thicker flanges design but their fitment with the driver side just isnt teh greatest
Old Oct 21, 2005 | 09:30 PM
  #24
reincarnating an older post
after having my headers done for a while and all is good after some tweaking
i was just wondering , how many ppl that have had clearance problems with teh jethot headers and had their subframe connectors instaled b4 hand
did u have ur SFCs put on on a post life or on a drive on
i had mine put on when it was on a post lift, at the time i did not knwo that that was bad and apparently teh mechanic wasnt smart enough to realize it , but teh car sits perfectly level and straight, but would this have contributed to my clearance problems and anyone elses?
but im just wondering if its a bad design or a default of other sort
Old Oct 22, 2005 | 12:00 AM
  #25
sko_spo's Avatar
on my install with the jet hots my hooker y-pipe wasnt clearing on the driver side frame , right by the tranny cross member . It looked like the bend was in the wrong spot. I even ordred another from the company and they said they never had a problem . so i took it to a exhaust shop were he re-cut and welded it.
Old Oct 22, 2005 | 01:25 AM
  #26
ok , im just trying to c if its some sort of design flaw or if its b/cof other things that have been done to teh car , mostly stiffening the chassis or body to where it could effect teh clearance problems
HarleyZ28
Oct 5, 2015 06:23 AM
jasonduaine
Apr 1, 2015 08:09 PM
Fatdog2
Mar 31, 2015 06:50 AM
LT14LIFE
Feb 9, 2015 09:35 PM
omarECD
Aug 19, 2002 07:28 AM
