Jet hot slip fit?
Old Feb 9, 2004 | 04:38 PM
96ta(nick)'s Avatar
Jet hot slip fit?
Can i use copper rtv or something to keep the slip fit primary from leaking?
Old Feb 9, 2004 | 04:39 PM
QCKZ28's Avatar
a 1 3/4" t bar clamp from summit will work, i doubt any RTV could withstand the heat.....
mine doesnt leak at all with just the t bar clamp
only $6.95
jesse
Old Feb 9, 2004 | 04:51 PM
96ta(nick)'s Avatar
think autozone or oreilley(sp?) might have something?
Old Feb 9, 2004 | 04:54 PM
QCKZ28's Avatar
i doubt it.....
Old Feb 9, 2004 | 04:56 PM
ibanez6rg's Avatar
RTV won't withstand the heat.
Old Feb 9, 2004 | 04:59 PM
96ta(nick)'s Avatar
Originally posted by QCKZ28
i doubt it.....
where else can i get a clamp locally? lowes or home depot maybe?
Old Feb 9, 2004 | 05:04 PM
97 RedSS's Avatar
Weld It
Cody
Old Feb 9, 2004 | 05:16 PM
96ta(nick)'s Avatar
Originally posted by 97 RedSS
Weld It
Cody
yeah but then can i still get it in with the motor in the car?
Old Feb 9, 2004 | 05:20 PM
CamaroBoy96Z28's Avatar
Do you even have problems with leakage? I dont use anything and my slip in primary doesnt leak at all.
Old Feb 9, 2004 | 05:31 PM
96ta(nick)'s Avatar
it is loose, im pretty sure it is going to leak
Old Feb 9, 2004 | 05:49 PM
jonaddis84's Avatar
Ultra Copper RTV would withstand it, had that on my MACs, stayed there for awhile, good up to like 1200*, headers wont see near that.
Anyway, how does a clamp do anything since it is solid tube? I could see if it had a slit like most slip fits. Or did you cut a small slit in it?
Old Feb 9, 2004 | 08:28 PM
QCKZ28's Avatar
no i did not cut my JET HOT headers
i just put the clamp on....
some ppl have problems with it leaking, some dont, i didnt want to take a chance, so i put the clamp on there.
jesse
Old Feb 10, 2004 | 07:13 PM
95 Silver TA's Avatar
Does the Hooker LT have a slip fit primary too or just the Jet Hot LTs?
Thx,
Claude
Old Feb 10, 2004 | 07:15 PM
Transamdriver's Avatar
Thx,
Claude
They both do to help go around the steering linkage. Mine Hooker slip fit doesnt leak at all, I did put a dab of super copper, but then I had to take the headers back out to do something before I finished installing them and it made it a pain in the *** to take it out, so I cleaned it off with brake parts cleaner.
Old Nov 9, 2004 | 10:45 PM
Dave88LX's Avatar
Re: Jet hot slip fit?
I'm putting my Jet Hots on right now, I couldn't get the slip fit in far enough so I touched it up with some 220 grit, now it seems way too damn loose. :livid:
Anyone have a pic of this clamp I need?!?
