Jet Hot LT driver side primary?
I just got my Jet Hot LT's today, and I noticed that the driver's side primary is not connected. Does that have to be welded on or is it fine to just leave it connected after the install?
Just wondering if you're putting the headers on yourself or if you're getting a shop to do it. I'm planning on tackling mine when they get here, i know i have the tools to do it but wondering what problems are common with the install or if anyone has a link to a good tech article to go by.
btw i'm getting the jet hots too.
Originally posted by FormulaLT-1
I did it myself... they were easy with the motor on the stand.
then you just put the motor in.
I had to lift the motor about 2-3", not really hard to do, just a 2x4 on the floor jack.
The bigest thing is to remember to get the car as high in the air as you can... I used a set of 24" jackstands, and it was just enough for the PS header, you have to put it in almost vertical...
Yeah, i'm just hoping i can do the passenger side from the bottom without lifting the motor.
