Jet Hot LT driver side primary?
Old Apr 14, 2004 | 08:54 PM
25thBird's Avatar
I just got my Jet Hot LT's today, and I noticed that the driver's side primary is not connected. Does that have to be welded on or is it fine to just leave it connected after the install?
Old Apr 14, 2004 | 09:05 PM
FormulaLT-1's Avatar
it is a good press fit, no welding required, I did have to use a wire brush bench grinder to get it on there.
Old Apr 14, 2004 | 09:49 PM
25thBird's Avatar
good to know, i was hoping i didn't have to have it welded...
Old Apr 14, 2004 | 10:08 PM
CamaroBoy96Z28's Avatar
Yup no welding. Its the same as the Hooker design with the slip fit primary. I sanded a little to get it to go on and no leaks after nearly a year.
Old Apr 14, 2004 | 10:16 PM
screamin94Z's Avatar
Just wondering if you're putting the headers on yourself or if you're getting a shop to do it. I'm planning on tackling mine when they get here, i know i have the tools to do it but wondering what problems are common with the install or if anyone has a link to a good tech article to go by.
btw i'm getting the jet hots too.
Old Apr 14, 2004 | 10:22 PM
I did it myself... they were easy with the motor on the stand. then you just put the motor in.
Old Apr 14, 2004 | 10:26 PM
25thBird's Avatar
I'm gonna be putting them in with the help of some friends. We have done a few header installs on LS1's before. But this will be our first LT1.
Old Apr 14, 2004 | 11:39 PM
25thBird's Avatar
so you had to jack up your motor? i'm really hoping i don't have to go that route.
Old Apr 14, 2004 | 11:49 PM
blown383's Avatar
Its not that hard to do...just take your time and you'll be okay with it.
-B
Old Apr 14, 2004 | 11:51 PM
25thBird's Avatar
thank's for the reassurance...
Old Apr 14, 2004 | 11:57 PM
slowpoke96z28's Avatar
i think he meant an engine stand. but you can do it in the car just fine. i think its easier from the bottom with the spark plugs out myself.
Old Apr 15, 2004 | 12:00 AM
25thBird's Avatar
engine stand, duh Yeah, i'm just hoping i can do the passenger side from the bottom without lifting the motor.
Old Apr 15, 2004 | 06:23 AM
97FormulaWS-6's Avatar
I had to lift the motor about 2-3", not really hard to do, just a 2x4 on the floor jack.
The bigest thing is to remember to get the car as high in the air as you can... I used a set of 24" jackstands, and it was just enough for the PS header, you have to put it in almost vertical...
Old Apr 15, 2004 | 06:46 AM
curly's Avatar
The install wasn't a real bad deal and it was even easier since we had the tranny out . Just be sure you can get the car off the ground a good distance. We had mine about 2' off the ground.
Old Apr 15, 2004 | 07:16 PM
25thBird's Avatar
great info guys, thank's
