jet hot long tubes installed
Old Dec 18, 2003 | 12:24 PM
jay g's Avatar
hey, just did the jet hot long tube install, it went very smooth, a very easy install,
i did not recieve my y-pipe yet but as i look at the drivers side header it looks like it is pointed right at the trans crossmember,
does anyone else with the lt1 jet hots have any pics of the drivers side header from the bottom, i would like to see how others look when installed, i can take pics if anyone wants to see mine,
also the drivers side collector flange is right tight against the floor, and i have brand new gm motor mounts and a pa k-member
it just does not look like there is any way a pipe or collector will fit on the drivers side
thanks, jay
camaro1@wctc.net
Old Dec 18, 2003 | 12:47 PM
SVT Killer LV's Avatar
must be nice to have a K-Member
Old Dec 18, 2003 | 12:53 PM
jay g's Avatar
yup the headers slipped right in clearance is very good,
just looking to see if my drivers side is positioned the same as other lt1 jet hots,
jay
camaro1@wctc.net
Old Dec 19, 2003 | 03:11 PM
jay g's Avatar
ttt
Old Dec 25, 2003 | 02:52 PM
Mullet Z28's Avatar
I have this same problem with my Jet Hot long tubes. I have a custom y-pipe that was made for Hooker long tubes, and there's no way it's going to fit on the Jet Hot collectors. So it looks like the Hookers and Jet Hot are different after all.
Old Dec 25, 2003 | 04:51 PM
stang_killa94's Avatar
Re: jet hot long tubes installed
thanks, jay
camaro1@wctc.net
Pics in 2nd page of cardomain site. Although its a custom y pipe
Old Dec 25, 2003 | 06:46 PM
jay g's Avatar
in order to fit my hooker y-pipe i had to make a new trans crossmember to drop the trans 3/4", and i had to cut a 1/4" out of the drivers motor mount bracket and re weld it together, then it fit perfect,
Old Dec 25, 2003 | 06:56 PM
Birdman7389's Avatar
weird, mine fit fine with my hooker y-pipe....BTW did you get those pics Jay G?
Old Dec 26, 2003 | 11:32 AM
jay g's Avatar
yes thanks for the pics, after seeing how yours fit i knew my hooker y-pipe would not work, until i got the engine and trans lowered to get some clearance.
but it was an easy fix, plenty of clearance now the headers and y-pipe look and sound great,
i used a little high temp silicone around the pipes that slid into the y collector and at the #1 slip joint and no leaks
also the bolts that come with the headers suck, the 7/16 head is too big 1/2 of the bolts you can only use an open end wrench to tighten them, i bought a set of heddman bolts with a 3/8 hex head now i can tighten all the bolts with a socket or box end wrench
Old Dec 26, 2003 | 12:54 PM
yep, I got the ARP's with a 12 pt 5/16 head, they are stainless and very easy to get to.
Old Dec 26, 2003 | 01:34 PM
Red96Lt1's Avatar
I didn't have a problem with my Hooker Y pipe fitting to my Jet hot's.
LT14LIFE
Feb 9, 2015 09:35 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
