jet hot headers for LT1s..in here
Old May 8, 2003 | 05:42 PM
doodad's Avatar
Question jet hot headers for LT1s..in here
Ok just got the headers and they are beautiful. But, what about that slip fit tube? Mine seems like the same size as the main header and sure doesn't want to go in the tube. Has anyone else had this problem? Or do yours fit all the way into the connector? Mine sure won't unless I am planning to beat the crap out of them (in the engine bay I can only imagine the problems). Thanks.
Bart
Old May 8, 2003 | 05:53 PM
joeSS97's Avatar
Use some fine emery cloth and lightly sand the very end so it tapers.Dont over do it.You want a tight fit.I have Hookers and beat mine in with a piece of wood.Also put a little anti sieze on it.
Old May 8, 2003 | 06:59 PM
94ZVert's Avatar
Yep, I had to sand it down a little to make it fit. No problems so far.
Old May 9, 2003 | 10:28 AM
SantaCruz163's Avatar
I suggest heating up the tube that is on the outside so it will expand and you will be able to fit the header tube in.
Old May 9, 2003 | 11:04 AM
GetaZforgetGT's Avatar
I sanded mine down and just twisted it in.
I would be leary of heating up the tube. A torch gets a lot hotter than 1200* which the coating is rated at. I just sanded mine and tested it....sanded a little more.
You want to make sure it is as tight as possible so it doesn't leak.
HarleyZ28
Oct 5, 2015 06:23 AM
Drtryder
Apr 22, 2015 04:17 PM
Fatdog2
Mar 31, 2015 06:50 AM
LT14LIFE
Feb 9, 2015 09:35 PM
GigaMp3z
Feb 20, 2003 02:57 PM
