Jet-Hot header A.I.R. fitting problem - sent the wrong thing?
Old May 25, 2004 | 08:42 PM
1996 | Z28 SS's Avatar
I just got my driver side header in, and I went to screw in my AIR fitting.. and it's too small! (my old fitting is too small, the diameter on the jet-hot injection tube is too big)
Did they send the wrong thing? Am I doing something wrong?
Thanks!
Old May 25, 2004 | 08:50 PM
Spinner's Avatar
Later Z28s used a smaller AIR tube. You got the early style header (22mm instead of 18mm)
Old May 25, 2004 | 09:39 PM
What should I do? Can I just take it to a Home Depot or somewhere and just have them find a 22mm peice?
Old May 25, 2004 | 09:53 PM
Spinner's Avatar
They wouldnt stock it. If you just want to plug up the hole, you'll need a 22mm drain plug, M22x1.5 is the thread size.
Old May 25, 2004 | 10:00 PM
I know they wouldn't stock the exact peice that I need.. but wouldn't they have some sort of 18mm - 22mm adaptor? I want to avoid just sticking a plug in.
Old May 25, 2004 | 10:09 PM
Spinner's Avatar
Not likely that any such adapter is made
DirtyDaveW
Dec 1, 2016 05:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
Hal Fisher
Sep 14, 2002 09:36 PM
