Jet has a new MAF
Old Jun 27, 2008 | 05:13 PM
MeanGreen97Z's Avatar
Jet has a new MAF
Says it flows 48% more on a flow bench. It's also one of those pre-programmed MAF meters like the ones for the Mustangs. Wonder if it's any good.
Old Jun 27, 2008 | 05:30 PM
MEAN LT1's Avatar
Nothing wrong with the stock ones unless your running big boost.
Old Jun 27, 2008 | 07:27 PM
bombebomb's Avatar
Im curious also Meangreen, I know most aftermarket mafs have gone down hill, but this is new and im just curious hehe.
Old Jun 27, 2008 | 11:22 PM
The BBK ones for the 5.0 Mustangs work like a charm.
Old Jun 28, 2008 | 01:21 AM
MarcR94v6's Avatar
new lt1 product....interesting.
Old Jun 30, 2008 | 05:45 AM
awdfun's Avatar
Its a ls2 style maf
Old Jun 30, 2008 | 05:59 PM
The question is will it be an improvement?
Old Jun 30, 2008 | 06:28 PM
WS6T3RROR's Avatar
nope.....
Old Jun 30, 2008 | 07:07 PM
MarcR94v6's Avatar
yea, you won't catch me being the guinea pig either.
Old Jun 30, 2008 | 08:59 PM
WS6T3RROR's Avatar
Guinea pig's ****. Until you max the stocker out you arent going to gain enough to worry about it and even then its marginal. Doesnt get much more free flowing than a round channel. That little screen in there isnt hurting a thing.
The only reason anyone ever saw a gain descreening thier maf or putting in a different one is because the stock wot tune on the lt1 is a pos and its about0.75-1 full a/f ratio rich in my experience. The descreened maf screws up the calibration and it reports less air so less fuel is injected and you make more power because you're running a more correct a/f. The downside is it screws up your low airflow readings and fuel trims nicely. Too bad you spend all day at airflows between 25-70grams/sec without getting on it, right where it screws it all up good.
Bigger maf's I can sort of agree with but you better be making some REAL hp before you start worrying about that. I've seen a couple guys who were making 550-580fwhp on the engine dyno switch to a large size lsx type maf and pick up almost 5hp after tuning, dare to dream.
GREEN3112
Feb 10, 2019 09:19 PM
Double aught
Oct 2, 2015 11:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
