jet fan switch
Old Jun 30, 2004 | 02:17 PM
motownz's Avatar
Question jet fan switch
Has anybody installed the JET fan switch on a 93?
Do you have to drop the starter or what?
Old Jun 30, 2004 | 04:00 PM
dogboy's Avatar
I ran my sensor off the small water hose between the intake & radiator. I used a tee fitting and ran the sensor into that . you need to run a ground wire to the tee.
Old Jun 30, 2004 | 04:55 PM
Fuels94TA's Avatar
I did the same thing as dogboy. Instead of messing around with that plug on the block. It took me 15 min. to install the sensor.
Vinny
Old Jun 30, 2004 | 08:10 PM
96capricemgr's Avatar
I know on the 93 it is a tad different but still I would just look into pcm reprogramming to get the fans on lower, and see so many other benifits from it to.
Old Jun 30, 2004 | 08:12 PM
Bud M's Avatar
I put mine in the head. You can do it from above. You need an 8 mm drain plug socket to remove the screw from the head.
Jeff'SS
Jun 1, 2015 06:21 AM
chesee48
Aug 22, 2002 08:28 AM
BLACK Z !
Sep 25, 2001 11:37 AM
BLACK Z !
9
Aug 11, 2001 05:46 AM
