jet chips suck
Old Mar 28, 2004 | 06:47 PM
badblackta's Avatar
jet chips suck
I found a jet chip in the computer of a 93 formula that was wrecked that my friend has and decided I would give it a try in my car. It ran good for like a few days then the car started running weird, it was stuttering and missing and not running right, but the cooling fans were on all the time(ac was not on). So I pulled the chip and put it back in thinking that it would reset itself and it did, for like another week. I was driving home and all the sudden my speedometer went to zero and the car started missing. I got to my driveway and put it in park, then it started idling at 1500 rpm. I shut it off and then the car would not start, and I could not hear my fuel pump come on when I turned on the key. I thought my fuel pump had died, but then I pulled the chip out and just put the prom in and it cranked right up. Next I swapped the computer out since I have a delphi computer I thought that putting a original computer in might fix the problem. I did that tuesday and I just pulled the chip out again because it was becoming hard to start and it wasnt running right. Anyone have any thoughts?
Old Mar 28, 2004 | 06:54 PM
Dave88LX's Avatar
So you're basing your opinion of a computer chip off of one that was pulled out of a wrecked car that you know nothing about?
Remind me not to ask you for advice...
Old Mar 28, 2004 | 07:01 PM
badblackta's Avatar
well being as it is just a standard tune for all 93 a4 cars I was expecting it to work properly. Just frustrated thats all. When the car runs, it runs awesome but then it just gets worse. I am confused with the thing.
Old Mar 30, 2004 | 11:50 AM
philcam01's Avatar
Dave88LX
He got the chip from me, and before you go opening your mouth he knows about the car that was wreck and i had the car running. we also put the computer from that car into his car and had the same problem, so unless you can be helpfull in this matter WHY POST AT ALL !!!!!!!!!!!!!!!!!!!!!
Old Mar 30, 2004 | 12:19 PM
Gripenfelter's Avatar
If you remove the chip and put the stock one back in and it still acts the same then its not the chip.
93s don't have a memory. Once you turn off the car the errors are erased.
Your problem is something else.
Old Mar 30, 2004 | 11:29 PM
badblackta's Avatar
no it runs fine with the stock prom but with the chip it will start to run weird.
Old Mar 31, 2004 | 12:04 AM
whatsup's Avatar
Since this is a topic for 93's...I'll put a plug in....check out this website that caters to the 93 f-bodyhttp://www.speeddensity.org/
GREEN3112
Feb 10, 2019 09:19 PM
Jeff1904
Jun 5, 2016 05:00 PM
Kawi
Sep 28, 2015 09:01 AM
drt
Sep 27, 2015 04:39 PM
92_RS_305
Sep 8, 2015 07:47 PM
