JB Weld Schrader Valve
Old Oct 3, 2006 | 09:44 AM
greggy2belly's Avatar
well my schrader valve has some small cracks which is pissing fuel everywhere. so i was wondering if it would b ok to just JB weld the spots that r pissing fuel?? like would it b strong enough, or would i have to get it welded back on??
thankss alot,
greg
Old Oct 3, 2006 | 09:56 AM
ta4me's Avatar
Re: JB Weld Schrader Valve
No, remove your fuel rail and take it to a welder. This happened to mine from the weight of my nitrous stuff. He welded it very carefully and havent had a problem with it for years. Only cost me 20 bucks.
Old Oct 3, 2006 | 10:33 AM
ok, thanks alot. the only problem i had was b4 i could not remove the fuel lines off the rail. i tries those circular fuel rail disconnect tools, but i couldn;t get the rail off.
but thanks alot, i will take it to a welder than.
Old Oct 3, 2006 | 10:35 AM
Javier97Z28's Avatar
Moderator
Should be fine if you don't mind dying from a fiery explosion at some point
Keep trying w/ the disconnect tool, push *up* and keep pressure on the line and it should pop right off.
Old Oct 3, 2006 | 01:30 PM
TraceZ's Avatar
Why not just go to the for sale section and buy a used fuel rail? $20 might get you a replacement.
JCSWS6
Jul 19, 2015 06:47 PM
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
Catmaigne
Jul 14, 2015 05:17 PM
