It's always one problem after another...need some advice
Old Mar 9, 2003 | 08:19 AM
96Z28man's Avatar
Ok, Since my cam/rocker install, now my top end is really good, but it seems as if my lower range sucks worse then before the cam. I have alot of stumbling. ALOT. So I am going to replace my opti and my coil, also going to get LT1 edit and tune my CPU. After this if it still not fixed and running like she should be, what else could the problem be? I will also replace the opti to if need be. The car has 73K on it.
Old Mar 9, 2003 | 08:34 AM
My recommendation would be to give your plugs, wires and coil some attention before doing the opti.
Old Mar 9, 2003 | 08:41 AM
joeSS97's Avatar
As usual,I agree with Shoebox.Do the easy stuff first.
Old Mar 9, 2003 | 08:49 AM
96Z28man's Avatar
that's what I was going to do. I am thinking about the future though. if fixing all the ignition stuff doesn't work, then what would the next thing to look at be?
Jun 6, 2015 08:27 AM
jj_burchiel
Mar 5, 2015 07:05 AM
edxiel
Jan 24, 2015 07:40 PM
tds1213
Nov 27, 2014 12:55 PM
smacz28
Aug 6, 2002 01:51 PM
