It's alive again!
Old Jun 18, 2008 | 04:32 PM
KyleBlue85Iroc-Z's Avatar
It's alive again!
So after being down since last October (tear down info), it's alive again! And better than it's ever been!
I got it running last week and have put ~150 miles on it. It's mean! It started up on the first try without any hiccups, even with the gas that was put in last October! It's still running in limp mode because it's throwing code 43 which revolves around the knock sensor. I'm thinking it was messed up because I left it on the block at the machinist's. It came back in a bag, who knows what happened to it.
Anybody changed the knock sensor with coolant still in the block? Anything else I should look for before I change that?
So I built this thing myself without ever pulling a motor before. I have to say, without this msg board I would have been SOL! You guys have to be the best wealth of knowledge. Better than any book!
I'll have pics up soon. Gonna go drive it some!
Old Jun 20, 2008 | 02:44 PM
anyone?
Old Jun 20, 2008 | 02:57 PM
Stl94LT1's Avatar
Once you pull the knock sensor, the coolant won't be in the block much longer.
Old Jun 20, 2008 | 03:01 PM
JohnD's Avatar
You can change the knock sensor but you are going to lose some coolant. The procedure for draining the block is to drain the radiator and then take out the knock sensor and the matching plug on the other side to completely drain the block. If you are fast, you shouldn't lose more than a quart or so-come to think of it, put a shop vac in the top of the radiator and the partial vacuum will keep any coolant from coming out.
Old Jun 20, 2008 | 03:12 PM
First let me say, I do realize that coolant will come out. I just meant is it possible to do it without making a gigantic mess? Or is it just easier to drain the radiator?
Old Jun 20, 2008 | 03:47 PM
JohnD's Avatar
Since draining the radiator leaves behind only the coolant that can be removed by removing the knock sensor, you are sort of stuck. Try the shop vac trick and you won't lose any.
C4m4roJoe
Jul 19, 2015 10:59 PM
madwolf
Aug 31, 2003 02:07 AM
Robert95z
May 30, 2003 06:00 AM
SVT Killer LV
May 28, 2003 04:10 AM
96ZRDR
Jan 27, 2003 10:25 AM
