Istalling heads and got oil on new 1074 gaskets
Old Apr 26, 2008 | 09:43 AM
95Blackhawk's Avatar
Hey all,
oil got on the gasket before I had a chance to tighten it down and it has soaked in but not all the way to the other side of the gasket.
Is this ok or should I use a new gasket now that I am ready to torque it down?
Old Apr 26, 2008 | 04:20 PM
If it were me, I would probably use a new gasket.
Old Apr 26, 2008 | 04:22 PM
mdacton's Avatar
If it were me, I would probably use it.
Old Apr 26, 2008 | 04:32 PM
MichiganSkip's Avatar
If it were me, I'd err on the side of caution
Old Apr 26, 2008 | 04:33 PM
There, that should make the decision perfectly clear!
IMO, surgically cleaning the deck and head surfaces just to throw on a gasket with oil on it doesn't make sense.
Old Apr 26, 2008 | 07:46 PM
Yep, 58 views and 3 suggestions. 2 against one. Looks like you'll be making a road trip.
Old Apr 26, 2008 | 07:51 PM
mdacton's Avatar
did you get oil on the gasket or is it soaked with oil?
Old Apr 26, 2008 | 07:53 PM
GreenDemon's Avatar
I've had friends at work clamp down a head with oil still leaking out of it and not have problems, but if it was me I'd probably use a new one unless it was terribly inconvenient. I don't even pull the gaskets out until I'm ready to set them on the block in order to avoid questions of "will this work or am I going to have to do it all over again?"
Old Apr 26, 2008 | 08:19 PM
ARZ28's Avatar
did the same thing go get a new one will save you alot of time in the long run when that one blows out and you could have done somthing about it.
Old Apr 26, 2008 | 10:38 PM
Will it hurt or won't it? Who knows for sure.
It's the ol' risk vs. reward scenario.
Old Apr 27, 2008 | 01:25 AM
Areas are soaked with oil. I would say 10% of the surface area is.
Old Apr 27, 2008 | 07:52 AM
mdacton's Avatar
well get a new one then. Not worth risking it considering all the work
Old Apr 27, 2008 | 01:02 PM
marshall93z's Avatar
I had oil seeping out from under my head when installing the gaskets from oiling the threads of the bolts.
No clue if it hurt anything... can't keep the POS running long enough!
Old Apr 27, 2008 | 04:53 PM
aboatguy's Avatar
If it happened to my head gaskets I'd spray them with brake cleaner; but I use Cometic MLS gaskets.
Just buy a new one for peace of mind!
Old Apr 27, 2008 | 05:04 PM
luckyou03's Avatar
I'd get a new gasket. Think about how much you will regret it if it blows and you have to tear the motor apart again.
