Issues Under 50%+ Throttle
Old Mar 16, 2009 | 08:51 PM
aaron1987's Avatar
I just brought my car out of storage today and was driving it around a bit and noticed that under half + throttle that something in the engine bay makes what I would describe as a clicking or punctuated semi-squealing noise and there's less power than there should be. The car still accelerates but doesn't have the oomph that should be there. I replaced the plugs last summer. Any ideas?
Old Mar 17, 2009 | 05:32 AM
Guest47904's Avatar
Guest
check the plugs, I bet one is loose. Just hope you didn't strip it like many others. The clicking sound you hear is exhaust coming out past the plug.
Old Mar 17, 2009 | 11:04 AM
aaron1987's Avatar
If it was a plug issue, wouldn't it be present all the time instead of just under heavy load?
Old Mar 17, 2009 | 11:34 AM
87bandit's Avatar
kinda sounds kinda like spun bearing
how's your oil pressure?
does the squeel sound muffled?
Old Mar 17, 2009 | 01:51 PM
aaron1987's Avatar
Oil pressure is good. It's hard to say if the noise is muffled or not, although it wouldn't be the first adjective that comes to mind in describing it. Haven't had time to get under the hood yet but in running errands today I haven't had the issue at all.. good power, no noises. I'm really confused now
Old Mar 17, 2009 | 11:20 PM
87bandit's Avatar
well if it's intermittent then I'd rule out bearing problems (unless we're talking about warm/cold engines)
94Form
Feb 10, 2015 11:23 PM
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Queens94z28
Dec 20, 2014 09:11 PM
