IROC intake on a LT1 engine?? help
Old Jun 29, 2008 | 04:28 PM
86IROC-LT1's Avatar
I'm in the process of doing a LT1 swap into my IROC and I was wondering will the IROC intake setup and boot work on the 97 LT1 engine with the MAS. Or would there be any kind of better setup for my LT1 to route to the IROC intake that mounts to the front of the car because I would like to use that setup. Maybe combining a corvette duct from the throttle body to the MAS then to a modified intake duct from there to the plastic intake?? Just curious if anyone has done this or know a way this can be done.
Thanks for the help.
-Ben
Old Jun 29, 2008 | 04:35 PM
mdenz3's Avatar
Why? The TPI intake belongs on a truck. The LT1 intake will work much better.
Old Jun 29, 2008 | 04:49 PM
96capricemgr's Avatar
Seems to me he is talking about the intake tract in front of the TB not the manifold.
Is the intake on your IROC any good? Basically asking if it is already modified or outright aftermarket. If stock it would likely be a big choke.
Old Jun 29, 2008 | 05:08 PM
94zgreenmachine's Avatar
It has been YEARS since I have messed with my old TPI Iroc. There is a mod you can do to take out the baffeling in the intake track, which is suppose to increase the air. There could be a problem with water, though. I never did get to test it out or even do the mod. A deer took care of that for me.
Old Jun 29, 2008 | 05:12 PM
chevyowner02's Avatar
There are some on thirdgen.org that has done a swap with the TPI air setup. And they said it was very restrictive. Just fab up a CAI you will be better off.
Old Jun 29, 2008 | 07:42 PM
red94chicken's Avatar
you would be better off using the lt1 style intake cause your stock iroc bellow will collapse if you have a health engine hooked to it.
Old Jun 29, 2008 | 09:41 PM
86IROC-LT1's Avatar
yea.... i thought since iroc airbox gave a straight shot from the air damn below to the throttle body it would be the best way to go, but also posted this same question on thirdgen.org and people on there also said that the setup i want to run using the original iroc airbox would be restrictive like some of you are saying. I'll have to look into the LT1 elbow and air cone, but im not sure if its going to fit since I had mounted the power steering res. next to my washer fluid res. and I'm not sure if theres gonna be enough room. But thanks for the help and If anyone else has any suggestions please share!
Here's a pic of the engine bay so far.
Old Jun 30, 2008 | 06:30 PM
86Camarolt1's Avatar
all I did for my intake is use the crome elbow with a rubber duct, went to lowes and got a straight 2ft piece of pvc and a 180 degree elbow with the K/N filter at end
Old Jun 30, 2008 | 08:03 PM
86IROC-LT1's Avatar
I was looking at the LT1 elbows... the MAF will mount to the end of the elbow before the filter cone, but what is that giant piece that goes straight down?? what does it do? and is it necessary??
Old Jun 30, 2008 | 09:32 PM
Thats the intake silencer. You can either run a plug in it(Fabricate one) or buy the 1LE intake elbow.
Old Jul 1, 2008 | 12:27 PM
Craddock's Avatar
You can get other ones than the 1LE intake elbow. There are more options, if you watch ebay you can get one cheap that's metal without the silencer.
Old Jul 1, 2008 | 09:09 PM
Sure, You can get an aluminum one from Summit. Either the trick flow or vortech elbows.Either way, they do not have the silencer on them. I have the Trick Flow. You will need to drill a small hole for the opti-spark, if yours is vented and the IAT senser will need to be threaded as well to fit into the elbow.
oldschool
Feb 9, 2016 09:21 PM
willismoons
Feb 14, 2015 08:42 PM
rockync7
Jan 1, 2015 05:10 AM
Jul 4, 2005 05:00 PM
