Intermittant spark
Intermittant spark
After my cam/head/header/tb swap, the right bank is running rich and the engine stumbles. Its obvious(?) that one of the wires on the right side is firing intermittantly????
What is the best way to diagnose which right side wire isn't firing consistently??
Originally posted by ibanez6rg
Check your wires and injector harness' (if 94+).
Also, what should I be looking for on the injector harness? Isn't there a tester commercially available, or is it feasible to test the resistance values to the computer?
Well since you just did heads/cam, you would have to pulled the harnesses off, check to make sure they're back in the right location. 93s don't matter, 94+ have a white number on the outside of the harness. Just make sure the wires coming from the opti are going to the according cylinder.
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
tommalcolm
Sep 11, 2015 03:39 PM
