Intermittant belt squeal at 2000 rpm?
Old Apr 4, 2007 | 01:34 AM
dregsz's Avatar
When I get on the gas from an idle at about 2k RPM it starts to squeal and sounds exactly like power steering low on fluid, but t topped off fluid the other night and checked to make sure it was still in there.
What else could it be?
Could just be a squealing belt.
how can I tell if I need to replace the belt? when it squeals? =P
this is actually poretty annoying, it shouldn't make this much noise. I've had the car for 2 weeks and it has no radio and this noise is present at least 50% of the time.
I can't pop the hood and get on the gas to see what it is since I cant be on the gas and under the hood at the same time.
I guess I'll need to call a bro to figure this out.
Any ideas or suggestions
thanks
Evan
Old Apr 4, 2007 | 02:58 AM
Heatmaker's Avatar
Advanced Member
You can get on the gas... just take a screw driver and use it to push down on the throttle body tab where it connects to the throttle cable (age old trick)
Look right underneath the black throttlebody cable cover and you'll see it.
How old is your belt? you can check your pulley tensioner... that can cause that... sometimes the altinator can cause that if the pulley isn't on tight enough... just some places to start.
Old Apr 4, 2007 | 09:48 AM
dregsz's Avatar
[QUOTE=Heatmaker;4518213]You can get on the gas... just take a screw driver and use it to push down on the throttle body tab where it connects to the throttle cable (age old trick) /QUOTE]
Duh, THanks, now why didn't I think of that
Old Apr 8, 2007 | 05:14 PM
Rob1997ta's Avatar
I have a 1997 trans am with a LT1 and I had the same thing and it was the belt tensioner. In stall new one and sound gone.
Old Apr 8, 2007 | 10:31 PM
dregsz's Avatar
sounds worth a try, any idea what one costs?
Evan
Old Apr 9, 2007 | 03:08 PM
2000GTP's Avatar
Probably around 50 bucks, give or take, not sure off hand.
Old Apr 9, 2007 | 05:05 PM
dregsz's Avatar
$24 at Kragen/Shucks, picked it up this afternoon.
I'll let you know if it's a fix later.
Evan
jocamino
May 14, 2015 07:37 AM
shroyvin56
Apr 3, 2015 08:15 AM
DetroitZ28
Feb 13, 2015 07:33 AM
jayvar
Feb 2, 2015 10:00 PM
ferraricameron
Jul 29, 2002 07:46 PM
