View Poll Results: How you fixed your fuel smell
Replaced EVAP canister
25.00%
Replaced EVAP lines
16.67%
Reconnected EVAP lines
0%
Replaced fuel pressure regulator
0%
Replaced fuel injectors
8.33%
Replaced gas tank cap
16.67%
Tightned fuel line
0%
Replaced fuel line
16.67%
Replaced EVAP purge solenoid-valve
0%
Leaking fuel rail
16.67%
Multiple Choice Poll. Voters: 12. You may not vote on this poll
Interior Gas Smell How it was fixed poll
Old Apr 10, 2003 | 08:32 PM
ryker77's Avatar
Exclamation Interior Gas Smell How it was fixed poll
What fixed your problem--- Not what you suggest
I've had a fuel smell problem in my car for sometime now. I've read alot and have found this to be a common problem. I want to know what you did to fix you problem.
This is for interior and engine bay smell. Not fuel smell towards the rear end of the car.
I don't want people who have never fixed this type of problem voting
Old Apr 10, 2003 | 08:38 PM
ryker77's Avatar
If I've left your problem out then please post a reply.
Also if you took the time to read this please bump this up to the top.
Old Apr 10, 2003 | 08:42 PM
chesee48's Avatar
i made my vote
EDIT: Whoops, i did exactly thhe opposite of what you said. I thought it ment to guess. i was confused..sorry..
but TTT!
Old Apr 10, 2003 | 08:44 PM
ryker77's Avatar
thanks
Old Apr 11, 2003 | 03:49 AM
HungryT/A's Avatar
Voted for leaking fuel injectors...
Old Apr 14, 2003 | 09:25 AM
ryker77's Avatar
Found my problem - Leaking FMU. Looks like after 45000 miles the screw came a little loose.
Old Apr 17, 2003 | 09:08 PM
ryker77's Avatar
ttt
Old Apr 18, 2003 | 11:22 AM
Terran2k's Avatar
whats an FMU?
Old Apr 18, 2003 | 11:41 AM
chesee48's Avatar
That wasnt even an option to pick from
so is it all fixed now then?
Old Apr 18, 2003 | 12:00 PM
RedWolf's Avatar
i replaced the winter gas with summer gas
Old Apr 18, 2003 | 12:27 PM
krispy's Avatar
my friend had that problem with his 95' T/A, the reason was the fuel lines in the engine compartment had melted slighty and were leaking, when it was getting fixed the guy moved the line, the melted part unsealed from whatever it was touching and gas sprayed all over, good thing the car was off at that moment
If you have a gas smell get it fixed, dont need ur car to randomly go up in flames
Old Apr 18, 2003 | 12:43 PM
97firechicken's Avatar
where can you get the canister from and how much do they cost?
Old Apr 18, 2003 | 02:55 PM
RedWolf's Avatar
i bought mine from Napa auto parts. Had to be a special order. Heres the Napa online description:
Echlin Fuel System Fuel Vapor Canister
Item#: CRB220104
Price: $ 53.99
tax and shipping not included
Usually ships in 24 hours.
Attributes:
Attributes: Fuel Vapor Canister
Diameter: 5 1/8''
Length: 7''
# of Hose Connectors: 2
Hose Size: 3/16'', 5/16''
Warranty: Limited 12 Months
Comments:
. w/ OEM # 17113065
Old Apr 18, 2003 | 03:20 PM
Wow sweet deal, thanks!
Old Apr 24, 2003 | 11:58 AM
ryker77's Avatar
ttt
Iamherefornow
Jan 26, 2015 04:57 PM
squarehead
Nov 21, 2014 08:02 PM
simple
Aug 11, 2002 11:56 AM
MislMan
Jul 19, 2002 11:41 AM
