Interesting vibration...very specific
Old Jan 12, 2006 | 03:05 PM
NoRegrets78's Avatar
Vibration occurs at 1500rpm, under crusing load at speed. Slight increase in throttle, goes away, slight decrease goes away. Get back to that maintain speed throttle position...vibration all over the place.
Harmonic balancer has slight wobble...very slight but noticable. Friend says motor mounts. Suggestions?
Old Jan 12, 2006 | 03:10 PM
Cmr0z28's Avatar
Re: Interesting vibration...very specific
Car? Mods?
Do you have an aftermarket exhaust? This is usually the #1 cause of vibrations at a specific RPM (due to resonance).
Old Jan 12, 2006 | 03:11 PM
My apologies...should have included that!
Stock 95 Z28.
Old Jan 12, 2006 | 04:57 PM
Deenasty's Avatar
where do you feel the vibration, in the steering wheel, pedals, console? I had a similar problem, turned out to be the driveshaft.. Could be a warped rotor, many things..
Old Jan 13, 2006 | 05:37 AM
Guest47904's Avatar
Guest
Try a few things. Try reving like that with the car sitting still. If you have a manual, also try in neutral with clutch in and out. Then put the rear up on jack stands and engage it and try reving the same way. Block the front tires unless you want to end up in the neighbors yard.
Old Jan 13, 2006 | 06:12 AM
RICEFEDZ28's Avatar
How many miles are on the car?
Old Jan 13, 2006 | 06:22 AM
130k miles on the car. Vibes seem to be everywhere but the wheel.
Revving while parked (a4) doesn't produce the same results. There is a slight vibration but I can't get that earthquake going.
Old Jan 13, 2006 | 07:57 AM
Stoopalini's Avatar
I'll put $20 down on U-Joints .....
Thomas.
Old Jan 13, 2006 | 09:48 AM
slow96z's Avatar
I'm going with U-Joints or driveshaft needs to be balanced.
Old Jan 13, 2006 | 11:12 AM
Strangely enough, this is my first RWD car and I said U or driveshaft initially.
Im replacing a few stock parts...I'll throw the harmonic balancer in just for ***** and giggles and if that doesn't solve the issue...def going with the driveshaft or U. Just wanted to get a consensus before I put all my eggs in one basket. Thanks guys! Love teh boards btw.
Old Jan 13, 2006 | 02:15 PM
Whether your problem or not, no balancer should ever wobble.
Old Jan 13, 2006 | 02:20 PM
Cmr0z28's Avatar
Yeah...that's not good
Old Jan 13, 2006 | 02:27 PM
Bersaglieri's Avatar
I took a stab in the dark with my horrible vibrations and threw in a LS1 DS my buddy had for sale. Fixed it right up, however looking at the stock DS I was glad I swapped it before it was too late.
-Dustin-
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
bunker
Aug 31, 2015 01:46 PM
karpetcm
Aug 14, 2015 03:02 PM
meissen
Aug 11, 2015 06:05 AM
gelbza
Jul 12, 2015 08:10 AM
